The DWA-171 Wireless AC Dual-Band Nano USB Adapter lets you experience faster wireless speeds than ever before by delivering powerful Wireless AC technology to your desktop or notebook computer. With its integrated dual-band technology, over the 2.4 GHz (150 Mbps) or 5 GHz (up to 433 Mbps) bands, you'll have reduced Wi-Fi interference to maximize throughput for faster video streaming, gaming, and VoIP calls.
Next Generation Wireless technology
Wireless AC for optimized performance and reliable coverage delivering HD video streaming, fast file transfers and lag-free video chatting. -
Dual band performance
Delivers fast wireless speeds and less interference for maximum throughput. -
Backward compatibility
It works with existing Wi-Fi routers and range extenders.
- D-Link Wireless AC DWA-171 - network adapter - USB 2.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 3.6 cm x 18 cm x 0.8 cm
- 5.4 g
- Data Link Protocol
- Wi-Fi 5
- Frequency Band
- 2.4 GHz, 5 GHz
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- System Requirements
- Microsoft Windows 7 / 8.1 / 10
- Network adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wireless
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Link/activity
- WPS
Aerial
- Antenna
- Internal
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Encryption Algorithm
- WPA, WPA2
- FCC Class B certified, IC
- OS Required
- 3.6 cm
- 18 cm
- 0.8 cm
- 5.4 g
- 0 °C
- 40 °C
- 10 - 95% (non-condensing)
