D-Link DUB-V310 - adapter - DisplayPort / HDMI / VGA - 11 cm
Quicklinx: HHL4WS00 Mfr#: DUB-V310
£29.27 ex VAT
£35.12 inc VAT
The DUB-V310 3-in-1 USB-C to HDMI/VGA/DisplayPort Adapter allows you to instantly add additional displays to your ultra-portable laptop. Just plug the DUB-V310 into an available USB Type-C or Thunderbolt 3 port and you are ready to expand your desktop workspace or display on additional/larger screens.
  • Output to 3 displays simultaneously
    Multi-stream transfer allows connection to 3 external displays at the same time, enabling greater productivity.
  • No installation required
    Simply connect to an available USB Type-C or Thunderbolt 3 port and enjoy HDMI, DisplayPort, or VGA video in seconds; no further installation necessary.
Cable
Adapter - DisplayPort / HDMI / VGA
Max Output Resolution
4096 x 2160 - 60 Hz
Cable Length
11 cm
Connectors
USB-C - male
Connectors (Second End)
HDMI - female , HD-15 (VGA) - female , DisplayPort - female
USB 3.1 Gen 1 / Thunderbolt 3 / DisplayPort 1.2
4K support
Cable Type
Adapter 4K support
Interface Supported
Cable Length
11 cm
60+ Hz refresh rate, DisplayPort Alternate Mode support, DisplayPort dual mode
Adapters & Converters
4096 x 2160
Refresh Rate
60 Hz
Apple MacOS, Microsoft Windows, Google Chrome OS
Connectors
24 pin USB-C - male
19 pin HDMI Type A - female , 15 pin HD D-Sub (HD-15) - female , 20 pin DisplayPort - female
Plug and Play, IC, FCC, RCM, HDCP 2.2
6.25 cm
4.05 cm
1.5 cm
44 g
Brand: D-Link
