D-Link DUB-E100 - network adapter - USB 2.0 - 10/100 Ethernet
Customer rating: 2.0* (Write a review)
Quicklinx: 2D8SWS00 Mfr#: DUB-E100
Wired / Wireless: Wired
Protocol: Fast Ethernet, Ethernet
Form Factor: External
Compatibility: PC, Mac
Type: Network adapter
More than 50 In Stock
£10.01 ex VAT
£12.01 inc VAT
The DUB-E100 is a high-speed USB 2.0 10/100Mbps Fast Ethernet adapter for Windows-based desktop and notebook PCs. This adapter is designed to simply plug into any available Universal Serial Bus (USB) port on your computer to connect you to a Fast Ethernet network. Based on USB 2.0, the adapter extends the transfer speed of earlier USB Fast Ethernet adapters to true 10/100Mbps connectivity.
The USB port of the adapter gives you throughput of up to 480Mbps to your computer. That's about 40 times faster than USB 1.1, the earlier USB specification. Now you can take full advantage of your Fast Ethernet network speed to transfer files, send e-mail and upload/download images.
As a USB device, this adapter eliminates the need to open your computer's cover to plug a network card into an expansion slot. It also saves your notebook's PC Card slot for other use. Installation and use are further simplified by living up to USB's out-of-the-box installation approach to connecting computer peripherals. You will not have to set IRQ's and other settings for your network connection. configuration is automatic at computer power up, and the adapter is hot pluggable. The DUB-E100 is equipped with an attached USB 2.0 cable that directly connects to any USB port on your computer. It is backward compatible with USB 1.1, so you can use the adapter with USB 1.1 ports as well (in case no USB 2.0 port is available). The DUB-E100 represents the simplest way to connect your computer to an Ethernet-based network.
The DUB-E100 supports USB's energy saving suspend and resume function to minimize power consumption, which is especially useful for laptop/notebook users. Power is provided directly by the USB bus, eliminating the need for an external AC power adapter.
Network adapter
External
Interface (Bus) Type
USB 2.0
Ports
10/100 Ethernet
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
IEEE 802.3, IEEE 802.3u
Linux, Apple MacOS X 10.4 - 10.7, Microsoft Windows Vista / XP / 7 / 8
Microsoft Certification
Works with Windows Vista
Network adapter
External
USB 2.0
Ports
10/100 Ethernet
Wired
Cabling Type
Ethernet, Fast Ethernet
Data Transfer Rate
100 Mbps
Status Indicators
Power, transmit, receive, link/activity
Full duplex capability
1 x 100Base-TX - RJ-45 - female - 1
1 x USB 2.0 - 4 pin USB Type B
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
FCC Class B certified, UL, VCCI
70 °C
5 - 95%
Customer reviews
Write a review for the D-Link DUB-E100 - network adapter - USB 2.0 - 10/100 Ethernet here!
A pain to install, but with a little work....
Reviewed by Jason Chapman. Review Posted 18/08/2009
Doing remote support, I need to be able to get a user to plug in and go. Unfortunately it is not plug and play. It seems to fail to install, I am assuming it finds the wrong .inf file on the cd. After uninstalling the failed install and manually installing by pointing it to the correct .inf worked fine.
  • Overall 3*
  • Ease of use 1*
  • Value for money 4*
Driver Problems
Reviewed by Tom. Review Posted 09/08/2008
The supplied drivers didn't work with this product, nor did the downloads from their web-site. In contact with theirv technical support but problem not fixed yet.
  • Overall 1*
  • Ease of use 1*
  • Value for money 1*
Driver Problem
Reviewed by . Review Posted 28/02/2008
The supplied drivers don't work for this item. I'm currently awaiting a response from d-link,having raised this issue with them.
  • Overall 1*
  • Ease of use 1*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Protocol: Ethernet
Compatibility: PC
Compatibility: Mac
Brand: D-Link
