D-Link DSL-2640B ADSL2/2+ Modem with Wireless Router
Customer rating: 4.0* (Write a review)
Quicklinx: 4SR4WS00 Mfr#: DSL-2640B
  • Wi-Fi CERTIFIED
With its built-in ADSL modem, the DSL-2640B connects to a phone socket and provides a secure and high-speed Internet access for homes and offices.
Setting up the router and adapter is easy even for non-technically minded people, with D-Link Click'n Connect: run directly from the product CD-ROM, this wizard takes you through an interactive step-by-step guide, including installation of the adapter.
A powerful dual firewall (SPI and NAT) prevents Denial of Service (DoS) attacks and attempts to breach your network from the Internet. You can also define a list of allowed sites to restrict web access during certain periods.
  • Enhanced security
    Equipped with 128-bit WEP, 64-bit WEP, and WPA2 encryption algorithms, this DSL modem ensures your network remains secure against unauthorized access and threats.
  • Versatile connectivity
    With support for Ethernet 10Base-T/100Base-TX and ADSL2+ interfaces, along with wireless capabilities, this device offers flexible options for both wired and wireless connections.
  • Comprehensive networking features
    Features such as DoS attack prevention, IGMP snooping, MAC address filtering, NAT support, and Quality of Service (QoS) provide a robust solution for managing network traffic and enhancing security.
  • High-speed Internet access
    Supporting ADSL, ADSL2, and ADSL2+ protocols, the DSL-2640B modem facilitates fast Internet connections with a maximum transfer rate of 24 Mbps, suitable for streaming, gaming, and downloading large files.
  • Easy network management
    Integrated 4-port switch and compatibility with Windows 7 allow for straightforward setup and management of your home or office network, ensuring a hassle-free Internet experience.
D-Link DSL-2640B - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Frequency Band
2.4 GHz
Network / Transport Protocol
PPTP, L2TP, ICMP/IP, IPSec, PPPoE, PPPoA
Routing Protocol
RIP, RIP-2, static IP routing
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP
Firewall protection, DMZ port, dynamic IP address assignment, DHCP support, NAT support, auto-uplink (auto MDI/MDI-X), IGMP snooping, SPI, DoS attack prevention, packet filtering, dynamic DNS server, MAC address filtering, VPN passthrough, WDS support, firmware upgradable, SNTP support, WMM support, QoS
IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11e
19.6 cm x 12.1 cm x 3.2 cm
327 g
Microsoft Certification
Compatible with Windows 7
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Routing Protocol
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA2, WPA-PSK
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11e, CSA, EN55022, EN55024, FCC Part 15 B, RoHS, EN 300 328
Built-in Devices
Radio access point
Status Indicators
Port status, power, status
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
ADSL, ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.4 (G.lite.bis), ITU G.992.5, ITU G.992.1 (G.DMT) Annex A, ITU G.992.5 Annex M, ITU G.992.3 Annex M
Max Transfer Rate
24 Mbps
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11 , Management: 1 x console
Aerial
Directivity
Omni-directional
External power adapter
1 x network cable , 1 x phone cable
19.6 cm
12.1 cm
3.2 cm
327 g
5 - 95%
Customer reviews
Write a review for the D-Link DSL-2640B ADSL2/2+ Modem with Wireless Router here!
Excellent Router
Reviewed by Anonymous Review Posted 07/05/2008
Excellent, works well. Gets a little hot but nothing to worry about.
RE: MAC Address filtering. Not checked mine, but MAC filtering is minimal security at best. MAC Spoofing is very easy to do, and so is capturing packets to find the address. Just use WPA2, MAC filtering is not worth the hastle TBH
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Excellent modem/router...
Reviewed by Richard Thomas. Review Posted 15/01/2008
Love it. I have no experience with networks, and this is my first venture into broadband, but had absolutely no problems installing this modem. As soon as you open the box, it says "Insert CD first!", so I did. The on-screen instruction are very clear and easy to follow, and it auto-configured my modem without a problem. Wireless transmission strength is ok, travelling through two rooms and upstairs in my semi easily enough, but then again I do have a Edimax free-aerial WiFi card in my desktop, not one of these silly little USB stick things. The result is a "poor" signal strength, but the transmission rate on "poor" is still three times my broadband connection speed, so there's no slow-down of internet at all :-) Box includes 2 micro-filters, an ethernet patch cable, and two DSL cables. Unit looks neat, although it would be nice to have a vertical mount stand to reduce its footprint a bit. Only had it one day, but I'd already recommend it :-)
  • Overall 5*
  • Ease of use 5*
  • Value for money 4*
MAC address filtering?
Reviewed by Dave L. Review Posted 28/02/2008
Had this modem/router foisted on me after my DSL-G624T died on me after 2 weeks. It took about 7 weeks from first reporting the issue with D-Link to get a replacement. Their email based support is woefully slow and formats the emails badly.
Generally happy with it apart from trying to set up MAC address filtering which is barely mentioned in the manual and not at all in the web based config utility.
I would probably not buy another D-Link product based on this experience.
  • Overall 3*
  • Ease of use 4*
Read all 4 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
