D-Link DPS-500A 156W Modular Redundant Power Supply
Quicklinx: CQGZWS00 Mfr#: DPS-500A
£362.28 ex VAT
£434.73 inc VAT
The DPS-500A redundant power supplies (RPS) are designed to conform to the wattage requirements of D-Link's Fast Ethernet and Gigabit switches. They provide a low-cost, simple solution to the problem of a failure of the internal power-supply of an Ethernet switch, which can result in the shutdown of that switching device, the devices attached to its ports, or an entire network. Supporting full output power for the switch, these redundant power supplies can maximize the availability of the switching device.
  • Redundant power backup
    Each D-Link RPS is equipped with an integrated detection circuit that continuously monitors the switching device's internal power supply. In the event of a power interruption, the redundant power supply is immediately triggered so that the LAN switch and its connected devices can continue providing service. This results in a more reliable network infrastructure and protects the network from a single failure of a network device power supply.
  • Easy and flexible deployment
    Deployment of a DPS-500A does not necessitate any change in configuration of the LAN switch. Each RPS is equipped with a universal internal power supply and can be connected to any AC main power source through a standard AC power cable.
D-Link DPS-500A - power supply - 140 Watt
Power supply
1.51 kg
Input Voltage
AC 115/230 V
Output Voltage
+5, +12 V
Power Capacity
140 Watt
17.2 cm x 25.7 cm x 4.3 cm
1-year warranty
DGS 3630-28SC, 3630-28TC, 3630-52TC; DMS 3130-30TS; xStack DGS-3120-48TC, DGS-3420-28SC, DGS-3420-28TC, DGS-3420-52T, DGS-3450, DGS-3620-28SC, DGS-3620-28TC, DGS-3620-52T
Power supply
Input Voltage
AC 115/230 V
Input Voltage Range
AC 90 - 264 V
Frequency Required
47 - 63 Hz
Output Voltage
+5, +12 V
Power Capacity
140 Watt
MTBF
400,000 hours
FCC Class B certified, CSA, cUL, EN 60950, UL 60950
Limited warranty - 1 year
50 °C
10 - 90%
17.2 cm
25.7 cm
4.3 cm
1.51 kg
D-Link DGS 3630-28SC, 3630-28TC, 3630-52TC , D-Link DMS 3130-30TS , D-Link xStack DGS-3120-48TC, DGS-3420-28SC, DGS-3420-28TC, DGS-3420-52T, DGS-3450, DGS-3620-28SC, DGS-3620-28TC, DGS-3620-52T
Brand: D-Link
