The Full HD Surveillance Starter Kit includes the 16-Channel PoE Network Video Recorder and 2 Full HD Outdoor PoE Mini Dome Cameras to allow you to start protecting your premise right away. Simply add hard disk(s) to the Network Video Recorder (NVR) and connect the cameras, to start monitoring and recording without the need of a computer.
Power over Ethernet (PoE)
With Power over Ethernet (PoE), the network video recorder supplies power to up to four PoE cameras, saving valuable time and electrical installation costs during set-up. -
Remote monitoring and playback
Managed by an integrated system, the recorder supports real-time remote monitoring and playback via a web browser through the recorder's graphical web interface. In addition, audio I/O support, digital I/O triggering and external USB 3.0 storage for video export and backup meet the needs of small businesses. -
Full HD outdoor PoE Mini Dome camera
The Vigilance outdoor PoE Full HD Mini Dome camera is a professional camera with full HD functionality, designed for easy installation and integration into a cost-effective video surveillance solution. Thanks to the integration of an IR LED projector, WDR and 3DNR, you get up to 30 meters of night vision with clear, detailed images in contrasting, low-light environments. The IP66-certified (weatherproof) camera housing is specifically designed to withstand extreme weather conditions. -
Vigilance range
The Vigilance range offers a complete professional video surveillance solution that's high-definition, easy to install and highly cost-effective. The range is made up of cameras specifically designed to meet different surveillance and environmental requirements. It ranges from stand-alone surveillance solutions that let you record video without additional software or hardware, to weather- and vandal-resistant cameras designed for harsh environments. -
Designed for security installers
Specifically designed for any security installer looking to offer digital video surveillance, this versatile range of cameras is designed to make selection and installation easy. You'll be able to guide your customers to the right choice for their needs, and they'll be delighted with the quality, reliability and ease of use offered by the Vigilance range.
- D-Link Vigilance Starter kit - DVR + camera(s) - wired (GbE)
- System
- DVR + camera(s) - wired - Ethernet 10Base-T/100Base-TX/1000Base-T
- Security DVR
- 16 channels
- Hard Drive
- 0
- Camera
- 2 cameras - outdoor - Dome - night vision
- 2.1 kg
- System
- Network Interface
- Remote monitoring
- Package Content
- 2 cameras, DVR
Security DVR
- Video Channels
- 16
- Frame Rate (Record)
- 30 fps
- Image Resolution
- 1920x1080
- Compression Format
- MJPEG, MPEG-4, G.711, G.726, H.264
- Record Events
- Alarm, motion detection, scheduled, event, manual, continuous
- RAID 0 support, RAID 1 support, RAID JBOD support, Pan/Tilt/Zoom support, 3-Dimensional noise reduction
Hard Drive
- Quantity Installed
- 0
- Quantity Supported
- 2
- Interface
- Serial ATA
- Supported Max Total Capacity
- 16 TB
Video Server
- ONVIF compliant
Cameras
- Quantity
- 2 cameras
- Camera Type
- Outdoor - Dome
- Sensor
- CMOS - 1/3" - 2 Megapixel
- Field of View
- 96° (H), 54° (V)
- Night Vision
- Infrared LEDs
- Infrared Distance
- 20 m
- Focal Length
- 1.8 mm
- Lens Iris
- Fixed iris
- Voltage
- DC 12 V / PoE
- Current Consumption
- 1.5 A
- -30 °C
- 50 °C
- Operating Humidity
- 20-80% (non-condensing)
- IP66
- Cameras Included
- 2 - outdoor - Dome
- Video Output Ports
- HDMI x 1, VGA x 1
- Audio Input Ports
- Mini-phone 3.5 mm x 1
- Audio Output Ports
- Network Port
- 10/100/1000Base-T
- Other Ports
- USB 2.0, USB 3.0 x 1
- 2.1 kg
- Details
- DVR: 2.1 kg , Camera: 11.3 cm x 11.3 cm x 7.77 cm
