D-Link dlink DNR-322L NVR
Quicklinx: 7TMXWS00 Mfr#: DNR-322L
mydlink™ Network Video Recorder
Comprehensive home monitoring solution for users who want to set up their own home security solution or small business owners who want to monitor and secure their offices or shops
The mydlink™ Network Video Recorder DNR-322L, enables users to record video simultaneously from up to nine network cameras without a computer being switched on. With support for mydlink™, a remote monitoring service unique to D-Link, the Network Video Recorder enables real-time remote monitoring and playback via a web browser using the mydlink™ website or the NVR's web GUI.
mydlink™ enabled: the easiest way to monitor your home, from wherever you are
Tool-less, hassle-free hard-drive installation
Product Highlights
- 2-bay Network Video Recorder, uses inexpensive 3.5" SATA drives
- mydlink™ enabled for the easiest way to monitor your home, from your iPad, iPhone or Android devices
- Record simultaneously from up to 9 cameras
- Simultaneous recording and playback
- Gigabit connectivity for fast transmission speeds
- User/group quotas for security and confidentiality
- RAID 1 technology to automatically mirror the contents of one Hard Drive to another
- D-Link Green™: energy-saving design
The mydlink™ Network Video Recorder is a standalone storage device that can record video simultaneously from up to nine network cameras1 without requiring users to turn on their PC. This device not only supports mydlink™ cameras but can be used to record footage from a range of D-Link business cameras, which makes it an ideal DIY security solution for both homes and small businesses. With mydlink™ technology, the DNR-322L can be accessed remotely via a web browser from any computer connected to the Internet, just by logging into your mydlink™ account. Once connected, you can watch live video from any of your cameras, or playback recorded footage with the intuitive on-screen controls. With no set up fees or subscription costs, home and business users have the most flexible way to ensure their properties are secure.
The easiest way to home monitoring
With the mydlink™ Network Video Recorder it has never been easier to create a complete monitoring system for your home or small business. Unlike other solutions that require users to change their network settings to access their NVR from the Internet, the DNR-322L is simple to manage and access. Simply run the installation CD, assign your NVR to your mydlink™ account or if you are a first time user, set one up, and you are ready to go. The DNR-322L will even automatically discover your D-Link cameras in your network for you.
A complete and flexible security solution
The DNR-322L is the perfect solution for small businesses or people that travel and need to leave their properties unattended for long periods of time. With 2 bays for standard, inexpensive Hard Drives, you can choose the recording capacity that best suits your needs. For example, two 3TB hard drives can store high-quality audio and video from four DCS-942L cameras for up to 6 weeks. The DNR-322L can be set up to record only during certain periods of time (for example, at night or during the weekends), or based on events, like on motion detection, so the recording capacity can be extended much longer.
Versatile monitoring
Users have a variety of options for viewing and organising camera footage on-screen. If multiple cameras have been set up in a property, users can simply drag and drop video from selected cameras to the viewing area.
Camera names and recording statuses are clearly displayed for easy reference. Users can control pan/tilt/zoom (PTZ) functions2 from within the interface or by directly clicking on the video.
2 Year Warranty
D-Link DNR-322L Mydlink Network Video Recorder - standalone DVR - 9 channels
Standalone DVR - 9 channels - networked
Compression Format
MJPEG, MPEG-4, H.264
Hard Drive(s) Supported
Quantity: 2
11.5 cm x 14.6 cm x 17.9 cm
0.9 kg
Standalone DVR
Video Channels
9
Compression Format
Package Content
Manual, DVR, external power adapter, software, cable holder
Network cable - 1 pcs.
FCC, RoHS
Security DVR
Networked
RAID 0 support, RAID 1 support, RAID JBOD support, security lock slot (cable lock sold separately)
Hard Drive
Quantity Supported
2
Serial ATA
Video Server
RAM
256 MB
ROM
128 MB
PTZ support
DDNS Support
Network Interfaces
Ethernet 10Base-T/100Base-TX/1000Base-T
Supported Protocols
DDNS, DHCP, DNS, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, UPnP, IPv4, PPPoE
ARP support, auto-uplink (auto MDI/MDI-X), IP address filtering, reset button, IPv4 support, DHCP client
Network Port
10/100/1000Base-T
Other Ports
USB x 1
Power Consumption
25.2 Watt
11.5 cm
14.6 cm
17.9 cm
0.9 kg
55 °C
5 - 90% (non-condensing)
7TMX C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.68
7TMX C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.87
Resources
The following resources are available for the D-Link dlink DNR-322L NVR
