The D-Link DIS N240-48 power supply is engineered to meet the demands of network hardware in diverse industrial environments. Offering a substantial 240 W of power and a flexible voltage output of DC 48 - 55 V, it ensures that your network components receive a stable and efficient power supply. Its wide operating temperature range from -20°C to 70°C allows for reliable performance in both extremely cold and hot conditions, making it an ideal choice for various industrial applications. Additionally, the DIN rail mountable form factor provides versatile installation options, catering to the unique needs of industrial settings. With its compatibility with a broad range of network hardware, the D-Link DIS N240-48 is a reliable and efficient power solution that supports the continuous operation of your network infrastructure.
Robust environmental adaptability
Designed to operate in a wide range of temperatures, the D-Link DIS N240-48 power supply ensures reliable performance from -20°C to 70°C. This adaptability makes it suitable for various industrial environments, ensuring your network hardware remains operational in both extreme cold and heat. -
Efficient power delivery
With a power provision of 240 W and a voltage output ranging from DC 48 to 55 V, this power supply meets the demanding energy requirements of network hardware. Its efficiency ensures that your devices are powered effectively, reducing energy wastage and operational costs. -
Versatile mounting options
The DIN rail mountable form factor of the D-Link DIS N240-48 allows for flexible installation options. This feature is particularly beneficial in industrial settings where space optimization and secure mounting are crucial for the efficient organization and operation of network components.
- D-Link DIS N240-48 - power supply - 240 watt
- Power supply - DIN rail mountable
- Output Voltage
- DC 48 - 55 V
- Power Capacity
- 240 watt
- Designed For
- DIS 100G-5PSW
- Input Voltage Range
- AC 90 - 264 V
- Output Voltage
- DC 48 - 55 V
- Power Capacity
- 240 watt
- -20 °C
- 70 °C
- Designed For
- D-Link DIS 100G-5PSW
