D-Link DIS M100G - Media converter - 1GbE - 1000Base-T - RJ-45 / SFP (mini-GBIC)
Quicklinx: GFSCWS00 Mfr#: DIS-M100G-SW
£146.97 ex VAT
£176.36 inc VAT
The D-Link DIS M100G media converter is engineered to bridge the gap between different network media types, offering robust connectivity solutions for industrial environments. With its dual RJ-45 and SFP connectors, it provides flexible integration options for a variety of networking setups. This device is built to withstand extreme temperatures, operating reliably in environments ranging from -40°C to 70°C. It supports high-speed Gigabit Ethernet, facilitating efficient data transmission with a data transfer rate of 1 Gbps. Compliant with IP30 standards, the D-Link DIS M100G is designed for durability and performance, making it an essential component for any industrial network infrastructure.
  • Robust connectivity
    Equipped with both RJ-45 and SFP connectors, this media converter facilitates seamless integration into a variety of network setups, ensuring reliable connectivity across different media types.
  • Wide temperature range
    Designed to operate in extreme conditions, the D-Link DIS M100G can withstand temperatures from -40°C to 70°C, making it ideal for industrial environments where temperature fluctuations are common.
  • High-speed data transfer
    With a data transfer rate of 1 Gbps, this media converter supports high-speed Gigabit Ethernet, ensuring efficient data transmission and reducing bottlenecks in network performance.
D-Link DIS M100G - media converter - 1GbE
Media converter - RJ-45 / SFP (mini-GBIC)
External
Cabling Type
1000Base-T
Data Transfer Rate
1 Gbps
1GbE
Media converter
External
Wired
Cabling Type
1000Base-T
1GbE
Data Transfer Rate
1 Gbps
1 x Ethernet 1000Base-T - RJ-45 female , 1 x - SFP
IP30
-40 °C
70 °C
Brand: D-Link
