D-Link DIS 100G-10S - Switch - unmanaged - 8 x 10/100/1000 + 2 x 100/1000 SFP
Quicklinx: H7WKWS00 Mfr#: DIS-100G-10S
£118.93 ex VAT
£142.71 inc VAT
The DIS-100G series industrial Gigabit unmanaged switches are designed specifically to withstand wide temperature range, vibrations and shock. These rugged, yet easy to deploy, switches have superior environmental specification compared to those of commercial network switches. With a hardened design combined with high availability network features, these switches form vital parts of any network infrastructure facilitating the increasing demand for smart cities, city-wide surveillance and wireless connectivity.
  • Rugged, hardened design
    Design to operate in wide temperature ranges. Vibration and shock resistance allows the switches to be deployed in enclosures or cabinets in outdoor locations.
  • Easily installation
    Simple Plug-and-Play installation with DIN-rail mounting ability.
  • Fanless design
    With no moving parts inside to reduce downtime and maintenance call outs, the rugged housing has been optimized for the transfer of heat.
D-Link DIS 100G-10S - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
Jumbo Frame Support
Fanless
5-year warranty
Enclosure Type
DIN rail mountable, wall-mountable
Subtype
Gigabit Ethernet
Ports
Jumbo Frame Support
Fanless
8 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP
Plug and Play, UL, FCC, IEC 60068-2-27, IEC 60068-2-32, IEC 60068-2-6, IP30, NEMA TS-2
Limited warranty - 5 years
-40 °C
75 °C
Brand: D-Link
