D-Link DIR-518L Wireless AC Mobile Cloud Companion
Quicklinx: 9TSPWS00 Mfr#: DIR-518L
  • IEEE 802.11n
Stay connected and charge your mobile devices with D-Link's DIR-518L Wireless AC Mobile Cloud Companion. It allows you to share wired or wireless Internet connections, or mobile Internet through a 3G USB adapter whether at home or away in a hotel room. Utilizing the latest Wireless AC technology to give extended wireless range and speed as well as dual-band support to help reduce interference.
  • Wireless AC for faster performance
    The DIR-518L incorporates the latest Wireless AC600 technology for increased range and data transfer speeds to and from compatible Wi-Fi devices. By using dual-bands to reduce radio congestion and interference, the DIR-518L can deliver a combined wireless speeds of up to 600 Mbps using both the 2.4 GHz and 5 GHz bands. Moreover, each band can operate as a separate Wi-Fi network, giving you the ability to customize your network according to your connectivity needs. You can even configure a guest zone to give visitors Internet access without giving them access to the rest of your network. Combined with support for Universal Plug and Play (uPnP), you can stream your multimedia collection smoothly and securely across all your devices and appliances, including smart TVs, game consoles, and media PCs.
  • mydlink SharePort - share on the go
    Sharing audio, videos, and photos is quick and easy with the DIR-518L. Using the mydlink SharePort app for mobile devices, you can upload, download, and stream multimedia and documents to and from a USB drive attached to your DIR-518L, from anywhere in the world! Simply download the app, register for a free mydlink account, connect to your DIR-518L, and you can start sharing your media files with your friends and family as long as you have access to the Internet.
  • Your power station
    The DIR-518L's powered USB port not only connects to a 3G dongle for mobile broadband, it also keeps your gadgets charged and ready to go. The wireless AC mobile cloud companion provides a USB port so you can charge a device by connecting its USB cable. Simply connect your smartphone or high-power devices like tablets to the USB port to start charging.
  • Easy to set up, easy to use
    The DIR-518L includes a user-friendly interface that stores your connection details for you so you only have to enter them once. Whether you're connected via your 3G adapter for mobile Internet or to the Wi-Fi hotspot of your favorite café, the DIR-518L helps you keep all of your devices connected, automatically!
D-Link DIR-518L - wireless router - Wi-Fi 5 - desktop
Wireless router
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft)
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
600 Mbps
NAT support, MAC address filtering, IPv6 support, Wi-Fi Multimedia (WMM) support, file sharing, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), reset button, SharePort Technology, USB charger, built-in rechargeable battery, wireless extender mode, Guest Zone support
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, USB 2.0, IEEE 802.11n, UPnP, IEEE 802.11ac (draft)
AC 100/230 V (50 - 60 Hz)
6.1 cm x 7.1 cm x 4 cm
130 g
Wireless router
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
600 Mbps
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, USB 2.0, IEEE 802.11n, UPnP, IEEE 802.11ac (draft), C-Tick, cUL, IC, FCC
Status Indicators
Power, status
WAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
Internal
External power adapter
6.1 cm
7.1 cm
4 cm
130 g
10 - 75% (non-condensing)
9TSP C2G 2m USB 2.0 A/B Cable - Black In Stock £4.17
