D-Link DIR-510L Dual Band AC750 Pocket Cloud Router
Quicklinx: 9TSNWS00 Mfr#: DIR-510L
  • IEEE 802.11n
The Connect and share an Internet connection, or charge your mobile devices anytime, anywhere, with D-Link's DIR-510L Wi-Fi AC750 Portable Router and Charger. Share files, stream media, and browse the Internet with the superb speed and performance provided by the latest Wireless AC technology. Simply connect your laptop, smartphone, or tablet to the DIR-510L's wireless network and it will take care of the rest. With the built-in high-capacity rechargeable battery, this portable charger gives power to your mobile device so that you can talk, listen to music, watch videos or surf the web for longer.
  • Wireless AC for breakthrough performance
    The DIR-510L incorporates the latest Wireless AC750 technology for unprecedented range and data transfer performance to and from compatible Wi-Fi devices. By using dual bands to bypass radio congestion and interference, the router can deliver a total of 750 Mbps using the combined bandwidth of its 2.4 GHz and 5 GHz bands. Moreover, each band can operate as a separate Wi-Fi network, giving you the ability to customize your network according to your connectivity needs. You can even configure a guest zone to give visitors Internet access without giving them access to the rest of your network. Combined with support for Universal Plug and Play (uPnP) and a built-in DLNA server, you can stream your multimedia collection smoothly and securely across all your devices and appliances, including smart TVs, game consoles, and media PCs.
  • Your mobile power station
    The DIR-510L's built-in high-capacity 4000 mAh rechargeable battery not only powers the device itself, it also keeps your gadgets charged and ready to go. The device provides two USB ports so you can charge a device and share files from a USB drive at the same time. You no longer have to worry about your smartphone's battery running out of juice while on-the-move. Simply connect your smartphone or high-power devices like iPads to the USB port to start charging anywhere, anytime.
  • Easy to set up, easy to use
    The DIR-510L includes a user-friendly interface that stores your connection details for you so you only have to enter them once. Whether you're connected via your 3G/4G adapter for mobile Internet or to the Wi-Fi hotspot of your favorite café, the DIR-510L helps you keep all of your devices connected, automatically
D-Link DIR-510L - wireless router - Wi-Fi 5 - desktop
Wireless router
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft)
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
750 Mbps
NAT support, MAC address filtering, IPv6 support, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), reset button, SharePort Technology, USB charger, built-in rechargeable battery
IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, USB 2.0, IEEE 802.11n, DLNA CERTIFIED, UPnP, IEEE 802.11ac (draft)
5.9 cm x 1.6 cm x 14 cm
154 g
Wireless router
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
750 Mbps
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, USB 2.0, IEEE 802.11n, DLNA CERTIFIED, UPnP, IEEE 802.11ac (draft), C-Tick, BSMI, cUL, IC, FCC, LVD, NCC
Status Indicators
Power, status, battery
WAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 2 x 4 pin USB Type A
Aerial
Aerial
Internal
External power adapter
5.9 cm
1.6 cm
14 cm
154 g
10 - 75% (non-condensing)
9TSN C2G 2m USB 2.0 A/B Cable - Black In Stock £4.17
