D-Link DHP-601AV PowerLine AV2 600 Gigabit Starter Kit
Quicklinx: B8GKWS00 Mfr#: DHP-601AV/B
Create a high-speed Home network at speeds of up to 1000 Mbps. The kit includes two Powerline AV2 1000 Gigabit Adapters. You can connect several different devices, from routers, computers, access points, gaming consoles, to Smart TV’s, bringing Ethernet network connectivity to hard-to-reach areas in your home. Each adapter will come with Gigabit connectivity so that you can stream more HD media, transfer all those large files and be online playing games with your friends.
  • Reduce power consumption up to 85%
    With its compact design and Power Saving Mode, the DHP-601AV consumes less power when compared with existing PowerLine Adapters. After a period of 5 minutes with no data transmission the Power Saving Mode will kick in and reduce power consumption by up to 85 percent.
  • Setup couldn't be any easier
    Just connect in one of your adapters to your router, connect the other adapter to your device. and then press the Simple Connect button to create a secure connection. It's that simple!
D-Link PowerLine DHP-601AV - AV2 1000 Gigabit Starter Kit - powerline adapter kit - wall-pluggable
Powerline adapter kit
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV) 2.0, IEEE 1901
Data Transfer Rate
1000 Mbps
Auto-negotiation
IEEE 802.3, IEEE 802.3u, HomePlug AV 2.0, IEEE 1901
6.22 cm x 3 cm x 8.747 cm
90 g
United Kingdom
1-year warranty
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
1000 Mbps
Encryption Algorithm
128-bit AES
Auto-negotiation
IEEE 802.3, IEEE 802.3u, HomePlug AV 2.0, IEEE 1901, UL, FCC, LVD
Status Indicators
Port status, power
1 x HomePlug AV 2.0 , LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Internal power supply
3.7 Watt
United Kingdom
6.22 cm
3 cm
8.747 cm
90 g
Limited warranty - 1 year
10 - 90% (non-condensing)
