D-Link DGS 3130-30-Ports Managed 10 Gigabit Ethernet Switch
Quicklinx: F3XQWS00 Mfr#: DGS-3130-30S/SI
Type: Gigabit Ethernet
Ports: 30
Data Transfer Rate: [N/A]
Managed: Yes
POE: No
£772.00 ex VAT
£926.40 inc VAT
The DGS-3130 Series switches are Lite Layer 3 Stackable Managed Switches designed to connect end-users in a secure enterprise or metro Ethernet access network. These switches support multicast, and enhanced security, making them an ideal Gigabit access layer solution.
  • Enhanced network reliability
    The DGS-3130 Series targets enterprises and metro Ethernet applications, and customers who require a high level of network security and maximum uptime. The DGS-3130 Series supports an external redundant power supply to ensure continued operation. The models also include reliability features, such as 802.1D Spanning Tree (STP), 802.1w Rapid Spanning Tree (RSTP), and 802.1s Multiple Spanning Tree (MSTP), Loopback Detection (LBD), and Broadcast Storm Control, that enhances network resilience.
  • Comprehensive security
    The DGS-3130 Series provides users with the latest security features such as Multi-layer and Packet Content Access Control Lists (ACL), Storm Control, and IP-MAC-Port Binding (IMPB) with DHCP Snooping. The IP-MAC-Port Binding feature allows administrators to bind a source IP address with an associated MAC and also define the port number to enhance user access control. With the DHCP Snooping feature, the switch automatically learns IP/MAC pairs by snooping DHCP packets and saving them to the IMPB white list.
  • Easy access control policies
    The DGS-3130 Series supports authentication mechanisms such as 802.1X, Web-based Access Control (WAC), and MAC-based Access Control (MAC) for strict access control and easy deployment. After authentication, individual policies such as VLAN membership, QoS policies, and ACL rules can be assigned to each host. In addition, the switch also supports Microsoft? NAP (Network AccessProtection). NAP is a policy enforcement technology that allows customers to protect network assets from compromised computers by enforcing compliance with network health policies.
  • Versatile traffic management
    The DGS-3130 Series implements a rich set of multilayer QoS/CoS features to ensure that critical network services such as VoIP, video conferencing, IPTV, and IP surveillance are given high priority. Traffic Shaping features guarantee bandwidth for these services when the network is busy. L2 Multicast support enables the DGS-3130 Series to handle growing IPTV applications. Host-based IGMP/MLD Snooping allows multiple multicast subscribers per physical interface and ISM VLAN to send multicast streams in a multicast VLAN to save bandwidth and to provide better security to the backbone network. The ISM VLAN profiles allow users to bind/replace the pre-defined multicast registration information to subscriber ports quickly and easily.
D-Link DGS 3130-30S - switch - 30 ports - Managed
Switch - 30 ports - L3 Lite - Managed - stackable
Subtype
Gigabit Ethernet
Ports
30 x SFP + 2 x 10 Gigabit Ethernet + 4 x 10 Gigabit SFP+
Performance
Switching capacity: 168 Gbps , Forwarding performance (64-byte packet size): 125 Mpps
Packet buffer size: 2 MB , Units per virtual stack: up to 32 , IGMP groups: 1024 , Virtual interfaces (VLANs): 4000 , QoS hardware queues: 8
MAC Address Table Size
16384 entries
Jumbo Frame Support
9KB
Routing Protocol
RIP-1, RIP-2, IGMPv2, IGMP, VRRP, IGMPv3, static IPv4 routing, static IPv6 routing, RIPng, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, TFTP, SSH-2, CLI, NTP
Flow control, BOOTP support, IGMP snooping, port mirroring, sFlow, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, DHCP server, MLD snooping, Cable Diagnostics Function, bandwidth control, LLDP support, DHCP relay, Port Security, DHCP client, SP, SIM, ERPS, 3 fans, IGMP filtering, system log, ICMP, MIB II, AAA, VLAN Double Tagging (Q-in-Q), WAC, DNS client, proxy ARP, EEE, BPDU Filter, WRR, HOL Blocking Prevention, loopback detection, Telnet server, Telnet client, Root Restriction
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1v, IEEE 802.1ab (LLDP), IEEE 802.3az
Power Redundancy
Optional
44 cm x 25 cm x 4.4 cm
3.21 kg
Subtype
Gigabit Ethernet
Ports
Performance
16384 entries
Jumbo Frame Support
9KB
Max Units In A Stack
12
Routing Protocol
Encryption Algorithm
SSL, SSL 3.0, SSL 2.0
Authentication Method
Secure Shell v.2 (SSH2)
24 x 1000Base-X SFP , 2 x 10GBase-T RJ-45 , 4 x 10GBase-X SFP+ , 1 x 10/100/1000 Base-T RJ-45 console , 1 x 10/100/1000 Base-T RJ-45 management , 1 x USB 2.0 Type A
Power Redundancy
Optional
82.4 Watt
MTBF
487,153 hours
FCC Class A certified, BSMI, cUL, CB, CCC, IC, VCCI Class A, RCM
Software Included
Standard Image (SI) Software
44 cm
25 cm
4.4 cm
3.21 kg
50 °C
10 - 90%
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
90%
Ports: 30
Managed: Yes
POE: No
Brand: D-Link
Price Range Ex VAT: £750 - £1000
