D-Link DGS-1250-52X 52-port Smart Managed Ethernet Switch
Quicklinx: FDBVWS00 Mfr#: DGS-1250-52X
Type: Gigabit Ethernet
Ports: 52
Data Transfer Rate: [N/A]
Managed: Yes
POE: PoE
Hurry, only 1 left in stock!
£281.36 ex VAT
£337.63 inc VAT
The D-Link DGS-1250 Series Smart Managed Switches deliver real value as an Enterprise Access and Small-to-Medium Business (SMB) Access/Aggregation solution. They provide a range of physical interfaces (including a Console Port with full CLI), multiple management interfaces, 11 Web languages, QoS enablement, and Advanced Layer-2 with Lite Layer-3 features.
The DGS-1250 Series switches support 24 or 48 x 10/100/1000BASE-T ports, with each switch also supporting an additional 4 x 10G SFP+ ports for optical connections using multimode or single-mode SFP transceivers - enabling real network horsepower at a value price.
  • Easy maintenance, less downtime
    The DGS-1250 Series supports Dual Image and Dual Configuration functionality, as well as a Console Port, all of which make it easier to configure, troubleshoot, and make other changes without interfering with network operation, while full Command Line Interface (CLI) functionality enables remote configuration, without the need for the Internet. And if a network issue ever does occur, the supported Spanning Tree Protocols (STP/RSTP/MSTP) help keep things running without interruptions or downtime.
  • Quality of Service (QoS)
    Automatic ConfigurationThe DGS-1250 Series supports Auto Voice VLAN and Surveillance Mode, which allow Voice and Video traffic to be automatically identified and handled differently from regular network traffic. Auto Voice VLAN detects Voice over IP (VoIP) traffic and automatically segments it from the rest of the network, increasing security and allowing Quality of Service (QoS) to be applied.
  • Extensive management and advanced features
    The DGS-1250 Series comes equipped with IGMP snooping, Port Mirroring, Spanning Tree Protocol (STP), and Link Aggregation Control Protocol (LACP). The IEEE 802.3x Flow Control function allows servers to directly connect to the switch for fast, reliable data transfers. The series also supports advanced features such as Static Routing, which allows for communication between different user groups in different VLAN segments in a network. And, because the switches can manage internal routing, the network router can be assigned to handle external traffic.
  • Management versatility
    The DGS-1250 Series comes with the D-Link Network Assistant (DNA) utility so admins can remotely control their network to the port level. DNA allows customers to easily discover multiple D-Link Smart Managed Switches within the same L2 network segment and display them onscreen for instant access.
D-Link DGS 1250-52X - switch - 52 ports - smart - rack-mountable
Switch - 52 ports - L3 Lite - smart - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 4 x 10 Gigabit SFP+
Performance
Switching capacity: 176 Gbps , Forwarding performance: 130.95 Mpps
MAC Address Table Size
32K entries
Jumbo Frame Support
12KB
Routing Protocol
IGMPv2, IGMP, static IP routing, IGMPv3, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON 1, Telnet, SNMP 3, SNMP 2c, SSH-2, CLI
Flow control, auto-negotiation, ARP support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, store and forward, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, sFlow, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, MLD snooping, DAI, reset button, LLDP support, DHCP relay, LACP, Port Security, SNMP trap, DHCP client, GVRP, dual firmware images, SPQ, Multicast filtering function, TFTP client, ERPS, cable test, system log, IP source guard, DRR, BPDU, ICMP, NTP, AAA, WAC, LLDP-MED, WRR, HOL Blocking Prevention, loopback detection
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3ae, IEEE 802.1s, IEEE 802.3az
44 cm x 21 cm x 4.4 cm
3.01 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
32K entries
Jumbo Frame Support
12KB
Routing Protocol
Encryption Algorithm
SSL, TLS, SSL 3.0, SSL 2.0, PEAP, TTLS
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2), Extensible Authentication Protocol (EAP)
: 1 GHz
RAM
2 GB DDR3 SDRAM
Flash Memory
64 MB
Status Indicators
Error, fan, link/activity/speed, stack
48 x 1000Base-T RJ-45 , 4 x 10GBase-X SFP+ , 1 x console RJ-45 management
Internal power supply
51.2 Watt
MTBF
589,984.72 hours
VCCI, C-Tick, BSMI, cUL, CB, FCC
44 cm
21 cm
4.4 cm
3.01 kg
-5 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 52
Managed: Yes
POE: PoE
Brand: D-Link
