D-Link DGS 1008MP 8-Port Desktop Gigabit PoE+ Switch
Quicklinx: CKQ6WS00 Mfr#: DGS-1008MP
Type: Gigabit Ethernet
Ports: 8
Managed: No
POE: PoE
13 In Stock
£73.34 ex VAT
£88.00 inc VAT
Something of a powerhouse when it comes to Power-over-Ethernet switches, this compact beauty offers PoE to 802.3af/at standard across all eight Gigabit Ethernet ports, at up to 30 Watts per port with a power budget total of 140 Watts. Which, put simply, means you can power devices such as access points, IP phones and video surveillance cameras simply by plugging them in with an Ethernet cable - no additional power required.
  • Power over Ethernet
    The DGS-1008MP features 8 10/100/1000BASE-T ports that support the IEEE 802.3at PoE protocol. Each of the 8 PoE ports can supply up to 30 watts, for a total PoE budget of 140watts, allowing users to attach an IEEE 802.3at-compliant device to the DGS-1008MP without requiring additional power. PoE is especially suitable for devices that are far from power outlets or when you want to minimize the clutter of extra cables. If a device is not PoE-compatible, the D-Link DPE-301GS PoE Adapter can turn any regular Ethernet port into a PoE Ethernet port.
  • Superior performance
    No configuration is required and installation is quick and easy. Support for Auto MDI/MDI-X on all ports eliminates the need for crossover cables when connecting to another switch or hub. Auto-Negotiation on each port senses the link speed of a network device and intelligently adjusts for compatibility and optimal performance. The switch has been designed without fans so you can be sure of quiet operation wherever it is installed. With wire-speed filtering and store-and-forward switching, the DGS-1008MP also maximizes network performance while minimizing the transmission of bad network packets. Combining the convenience of PoE, superior performance, and ease of use, the 8-Port switch with 8 PoE ports is the ideal choice for adding PoE devices to a small business or enterprise network.
  • Hassle-free setup
    The 8-port switch with 8 PoE ports is a plug-and-play device that requires no configuration, so setup is simple and hassle-free. D-Link provides a support website to answer all of your questions and help you get the most out of your network. Find answers to frequently asked questions, download product updates, and easily access the friendly D-Link Customer Support Team.
  • Compact and silent
    The DGS-1008MP has a sleek and compact design, so that you can place it in any easily accessible location and have it stay out of your way. The power connector and ports are all located at the rear of the switch allowing you to tuck the cables away conveniently. The DGS-1008MP does not use a fan, so the switch operates silently but effectively, letting you watch movies streamed off the Internet without distraction, or browse the web in peace.
  • D-Link Green Ethernet 3.0 technology
    DGS-1008MP switches feature both D-Link Green 3.0 technology and IEEE802.3az Energy Efficient Ethernet (EEE) to cut operating costs without sacrificing operational performance or functionality. With D-Link Green technology, the switches constantly monitor the link status and network utilization of every port. The switches also automatically detect cable length and can reduce transmission power usage for shorter cables. By pairing EEE capable devices with DGS-1008MP switches organizations can drastically reduce power consumption by automatically putting ports into a sleep mode when not being used.
D-Link DGS 1008MP - switch - 8 ports - unmanaged - rack-mountable
Switch - 8 ports - unmanaged
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Power Over Ethernet (PoE)
PoE
PoE Budget
140 W
Performance
Switching capacity: 16 Gbps
MAC Address Table Size
8K entries
Auto-negotiation, Energy Efficient Ethernet, flow control, full duplex capability, half duplex mode, auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3i, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3at, IEEE 802.3az, IEEE 802.3x, IEEE 802.3
28 cm x 18 cm x 4.4 cm
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
PoE
PoE Budget
140 W
Performance
8K entries
Status Indicators
Link/activity, PoE, port transmission speed, power, status
8 x 1000Base-T RJ-45 PoE - 30 W
External power adapter
13.5 watt
BSMI Class A, CB, CCC Class A, cUL, FCC Class A certified, LVD, VCCI Class A, RoHS, Plug and Play
28 cm
18 cm
4.4 cm
0 - 95% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% (non-condensing)
Ports: 8
Managed: No
POE: PoE
Brand: D-Link
