The DES-1016D 16-Port Fast Ethernet Unmanaged Desktop Switch is designed to enhance workgroup performance while providing a high level of flexibility. Powerful yet easy to use, this device allows users to simply plug any port to either a 10Mbps or 100Mbps network to multiply bandwidths, boost response time and satisfy heavy load demands.
Ease of use
The DES-1016D has 16 plug-and-play ports; the switch is a perfect choice for workgroups to upgrade performance in a client/server environment. The ports can be connected to servers in full-duplex, or hubs in half-duplex. -
Auto speed sensing
The switch senses whether a network device is running at 10Mbps or 100Mbps and automatically adjusts for optimal performance. -
Auto negotiation
Whether you are running at half- or in full-duplex, the switch automatically negotiates and runs the highest supported transmission rate. -
Auto MDI/MDIX crossover
All ports support auto-negotiating MDI/MDIX detection, which eliminates the need for crossover cables or uplink ports. The DES-1016D is the perfect choice for Plug-and-Play support for 10BASE-T and 100BASE-T networks. -
Wire-speed performance
The DES-1016D features a non-blocking wire-speed architecture, with a 3.2Gbps switching capacity, for maximum data throughput. The DES-1016D also features an integrated universal power supply, and per port diagnostics LEDs that make it easy to "spot check" for problems. With wire-speed filtering and store-and-forward switching, the DES-1016D maximizes network performance while minimizing the propagation of bad network packets.
- D-Link DES 1016D - switch - 16 ports - unmanaged - rack-mountable
- Switch - 16 ports - unmanaged
- Enclosure Type
- Rack-mountable
- Subtype
- Fast Ethernet
- Ports
- 16 x 10/100
- Performance
- Switching fabric bandwidth: 3.2 Gbps
- MAC Address Table Size
- 8K entries
- Flow control, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, QoS, Energy Efficient Ethernet
- IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 28 cm x 12.58 cm x 4.4 cm
- Enclosure Type
- Desktop, rack-mountable
- Subtype
- Fast Ethernet
- Ports
- 16 x 10/100
- Performance
- 8K entries
- Status Indicators
- Power, link/activity
- 16 x 100Base-TX RJ-45
- Power Device
- Internal power supply
- Voltage Required
- FCC Class A certified, cUL, ICES-003 Class A, C-Tick Class A, LVD, VCCI Class A
- 28 cm
- 12.58 cm
- 4.4 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.73 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £12.64 |
