The DES-1005D 5-Port Fast Ethernet Unmanaged Desktop Switch is a five port fast Ethernet switch that allows you to quickly set up a wired network.
Connect the DES-1005D to multiple computers together to share files and folders, or connect it to a router to share an Internet connection.
No configuration is required, making this switch completely plug-and-play.
Auto-Sensing 10/100 Ports
The DES-1005D 5-Port Fast Ethernet Unmanaged Desktop Switch uses auto-sensing 10/100 Mbps ports, allowing a small workgroup to flexibly connect to Ethernet and Fast Ethernet devices to create an integrated network. These ports detect the network speed and auto-negotiate between 10BASE-T and 100BASE-TX, as well as between full and half-duplex, allowing you to get the maximum speed possible for each device connected to your network.
Auto MDI/MDIX Crossover
All ports support automatic MDI/MDIX crossover, eliminating the need for crossover cables or uplink ports. Each port can be plugged directly to a server, hub, router, or switch using regular straight-through twisted-pair Ethernet cables.
Flow Control for Secure Transmission
802.3x flow control on each port minimizes dropped packets when the port’s receiving buffer is full. This gives you a more reliable connection for all of your connected devices.
- D-Link DES 1005D - switch - 5 ports - unmanaged
- Switch - 5 ports - unmanaged
- Subtype
- Fast Ethernet
- Ports
- 5 x 10/100
- MAC Address Table Size
- 2K entries
- Flow control, auto-sensing per device, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x
- 14.2 cm x 10.8 cm x 3.2 cm
- Enclosure Type
- Desktop
- Subtype
- Fast Ethernet
- Ports
- 5 x 10/100
- 2K entries
- Status Indicators
- Collision status, port transmission speed, port duplex mode, power, link/activity
- 5 x 100Base-TX RJ-45
- Power Device
- External power adapter
- 3.6 Watt
- Plug and Play, FCC Class B certified, VCCI Class B ITE
- 14.2 cm
- 10.8 cm
- 3.2 cm
- 0 °C
- 50 °C
- 10 - 90%
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £4.30 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.85 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £14.18 |
