D-Link DES 1005D Unmanaged 5x 10/100 Desktop Switch
Quicklinx: NJDWS00 Mfr#: DES-1005D/B
Type: Fast Ethernet
Ports: 5
Data Transfer Rate: 100Mbps
Managed: No
POE: [N/A]
£7.49 ex VAT
£8.98 inc VAT
The DES-1005D 5-Port Fast Ethernet Unmanaged Desktop Switch is a five port fast Ethernet switch that allows you to quickly set up a wired network.
Connect the DES-1005D to multiple computers together to share files and folders, or connect it to a router to share an Internet connection.
No configuration is required, making this switch completely plug-and-play.
Auto-Sensing 10/100 Ports
The DES-1005D 5-Port Fast Ethernet Unmanaged Desktop Switch uses auto-sensing 10/100 Mbps ports, allowing a small workgroup to flexibly connect to Ethernet and Fast Ethernet devices to create an integrated network. These ports detect the network speed and auto-negotiate between 10BASE-T and 100BASE-TX, as well as between full and half-duplex, allowing you to get the maximum speed possible for each device connected to your network.
Auto MDI/MDIX Crossover
All ports support automatic MDI/MDIX crossover, eliminating the need for crossover cables or uplink ports. Each port can be plugged directly to a server, hub, router, or switch using regular straight-through twisted-pair Ethernet cables.
Flow Control for Secure Transmission
802.3x flow control on each port minimizes dropped packets when the port’s receiving buffer is full. This gives you a more reliable connection for all of your connected devices.
D-Link DES 1005D - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Fast Ethernet
Ports
5 x 10/100
MAC Address Table Size
2K entries
Flow control, auto-sensing per device, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3, IEEE 802.3u, IEEE 802.3x
14.2 cm x 10.8 cm x 3.2 cm
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
5 x 10/100
2K entries
Status Indicators
Collision status, port transmission speed, port duplex mode, power, link/activity
5 x 100Base-TX RJ-45
External power adapter
3.6 Watt
Plug and Play, FCC Class B certified, VCCI Class B ITE
14.2 cm
10.8 cm
3.2 cm
50 °C
10 - 90%
Type: Fast Ethernet
Ports: 5
Managed: No
POE: [N/A]
Brand: D-Link
