The DCS-960L HD 180° Panoramic Camera is a revolutionary camera offering a horizon-wide view that easily captures your entire room, wall-to-wall, in high-quality 720p.
Unique de-warping technology
Maximizes the video quality with less distortion - letting you see more of your home at a glance. -
Home security in high definition
Crisp 720p HD video gives you a clear view of what's going on at home. See more of your favorite faces and places - it's home security with an eye for detail. -
Round-the-clock peace of mind
Peace of mind shouldn't end when the sun goes down. With 16 feet night vision, you'll never miss a thing. -
Easy to set up, even easier to use
Get your Wi-Fi camera set up in minutes, and place it just about anywhere in your home.
- D-Link DCS 960L HD 180-Degree Wi-Fi Camera - network surveillance camera
- Network surveillance camera - fixed
- Audio
- Yes: built-in microphone
- 9.6 cm x 9.6 cm x 13.8 cm
- 141 g
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1280 x 720
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Video Modes
- 720p
- Optical Sensor Type
- CMOS - 1/2.7" - 1 MP
- Minimum Illumination
- 0 lux - IR
- Focal Length Control
- Fixed focal
- Focal Length
- 1.72 mm
- Lens Iris
- F/2.0
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Voltage
- DC 5 V
- Date/time stamp, sharpness control, progressive scanning, resizing an image, saturation control, brightness control, contrast control, USB powered, Motion Detection Technology, light sensor, infrared cut filter, Sound Detection Sensor, hue control, Wi-Fi Protected Setup (WPS), reset button, Text Caption Overlay, password protection
- Environmental Parameters (operating)
- 0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
- Audio Support
- Wireless
- 9.6 cm
- 9.6 cm
- 13.8 cm
- 141 g
Camera
- Colour - Day&Night - fixed
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 1280 x 720
- Motion Detection
- Video Modes
- 720p
- Digital Zoom
- 8
- 0 lux - IR
- Infrared LEDs
- 2
- Infrared Distance
- 4.88 m
- Video Capture
- 1280 x 720 @ 30 fps , 800 x 600 @ 30 fps , 720 x 480 @ 30 fps , 640 x 480 @ 30 fps , 320 x 240 @ 30 fps
- Supported Image Formats
- JPEG
Image Sensor
- 1 MP CMOS 1/2.7"
Lens Construction
- Fixed focal
- Focal Length
- 1.72 mm
- Lens Iris
- F/2.0
- Horizontal Field of View (degree)
- 180
- Vertical Field of View (degree)
- 120
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, HTTPS, UPnP, IPv4, Bonjour, RTCP, PPPoE
- Ports
- USB (power only) - Micro-USB Type B
- Supported Memory Cards
- microSD Card, microSDHC Card
- FCC Class B certified, ICES, LVD
- Power Requirements
- DC 5 V - 1.2 A
- Power Device
- Power adapter - external (50/60 Hz)
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
