D-Link DCS-5030L HD Pan & Tilt Wi-Fi Dan/Night Camera
Quicklinx: CXGDWS00 Mfr#: DCS-5030L
  • microSD Card
Experience complete control with the ultra-smooth pan & tilt, HD quality and auto-recording functionality of the DCS-5030L. Monitor your home or small business from your smartphone or tablet.
  • Pan & tilt
    With sharp, responsive pan & tilt movement and 10x digital zoom, you can quickly scan a wide area and zoom in to see more details.
  • HD video quality
    The HD pan & tilt Wi-Fi camera delivers 720p HD video clarity, ensuring rich detail and crisp image quality for your surveillance recordings.
  • Motion detection with automatic recording
    The DCS-5030L detects movement - automatically sending an email or push alert to your mobile device. With the microSD card slot, you can also schedule auto-recording straight to any microSD card up to 32 GB.
  • Night Vision technology
    The HD pan & tilt Wi-Fi camera remains vigilant 24/7 with night vision capability, allowing you to see up to 26 feet in complete darkness.
  • Easy installation and flexible placement
    Setting up your HD pan & tilt Wi-Fi camera is easier than ever with our app-enabled installation wizard.
D-Link DCS-5030L - network surveillance camera
Network surveillance camera - pan / tilt
Audio
Yes: built-in microphone
10.91 cm x 11.64 cm x 13.36 cm
292.4 g
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
1280 x 720
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
720p
Optical Sensor Type
CMOS - 1/4"
Minimum Illumination
0 lux - IR , 1 lux - colour , 0.5 lux - B&W
Focal Length
2.38 mm
Lens Iris
F/2.2
Panning Range (degree)
-170 to +170
Tilting Range (degree)
-20 to +90
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage
DC 5 V
Date/time stamp, Motion Detection Technology, infrared cut filter, Sound Detection Sensor, Wi-Fi Protected Setup (WPS), text stamp, Event Notification, reset button
1-year warranty
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Audio Support
Wired, wireless
10.91 cm
11.64 cm
13.36 cm
292.4 g
Camera
Colour - Day&Night - pan / tilt
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1280 x 720
Motion Detection
Video Modes
720p
Digital Zoom
4
Infrared LEDs
Infrared Distance
5 m
Digital Video Capture Resolution
1280 x 720, 640 x 480, 320 x 240
Frame Rate (max)
Supported Image Formats
JPEG
Image Sensor
CMOS 1/4"
Lens Construction
Focal Length
2.38 mm
Lens Iris
F/2.2
Horizontal Field of View (degree)
94.36
Vertical Field of View (degree)
59.3
Panning
Range (degree)
-170 to +170
Titling
Range (degree)
-20 to +90
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, UPnP, IPv4, PPPoE, LLTD
Ports
LAN - RJ-45
Supported Memory Cards
microSD Card
Stand
FCC Class B certified, ICES, LVD
Power Requirements
DC 5 V
Power adapter - external 5.56 Watt
Apple MacOS X 10.7 or later, Microsoft Windows Vista / 7 / 8 / 10
Limited warranty - parts and labour - 1 year
Relative Humidity (operating)
