D-Link DCH-M225/B mydlink Home Music Everywhere
Quicklinx: 9T7TWS00 Mfr#: DCH-M225/B
  • IEEE 802.11n
The DCH-M225 Wi-Fi Audio Extender has the ability to stream your music to anywhere within your extended wireless network. DCH-M225 Wi-Fi Audio Extender is also a portable plug-in repeater that lets you extend an existing wireless network. Tiny yet powerful, it supports Wireless N speeds of up to 300 Mbps in a device that fits in the palm of your hand.
Unleash Your Music
Expanding your audio capabilities has never been easier with the help of the DCH-M225. With support for both DLNA and AirPlay, Stream all your music from your smartphone straight to any connected speaker. Jazz in the kitchen? Hip hop by the pool? Whatever your tune, wherever you want.
Wireless 802.11n for high-speed wireless
Wireless 802.11g/b backwards compatible
Wireless speeds of up to 300 Mbps
Security
WPA2/WPA wireless encryption to keep your wireless connection secure
Wi-Fi Protected Setup (WPS) for secure setup with the simple press of a button
Protocols
Wi-Fi WMM (Wi-Fi Multimedia) Quality of Service
Digital Media Renderer support (DLNA)
AirPlay support for iOS
Easy to Use
One-piece wall-plug design is compact, portable, and does not require additional power cables
Built-in Setup Wizard and QRS Mobile app for mobile devices guide you through installation
Wirelessly Stream Music with DLNA or AirPlay
Stream all your music from your smartphone straight to any connected speaker using DLNA or AirPlay
Enjoy high-speed wireless Internet connection
Extend your home broadband connection to enjoy wireless connection at speeds of up to 300 Mbps
Portable and easy to use
Simply plug it into a power outlet to extend a wireless network anywhere in your home. Easy one-touch configuration with WPS
Say Goodbye to Wi-Fi Dead Zones
As an added bonus, the Wi-Fi Audio Extender will expand your Wi-Fi coverage to improve connectivity for all your devices. It's not magic, but it's pretty darn close.
  • Unleash your music
    Meet the Wi-Fi audio extender. It lets you stream all your music from your smartphone straight to any connected speaker.
  • Fill your home with sound
    With support for both DLNA and AirPlay, it's simple to stream your music to any connected speaker within your home's Wi-Fi network.
  • Extends your Wi-Fi
    It's not just for music. The Wi-Fi audio extender can be used to easily eliminate Wi-Fi dead spots and bring wireless coverage to hard-to-reach areas in your home.
mydlink Home Music Everywhere - wireless audio extender - 802.11b/g/n
Wireless audio extender
External
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
802.11b/g/n
Remote Management Protocol
HTTP
AC 120/230 V
5.4 cm x 4.2 cm x 5.45 cm
81.2 g
External
Built-in Devices
2 x WiFi aerials
Wireless
802.11b/g/n
Data Transfer Rate
300 Mbps
HTTP
Frequency Band
2.4 GHz
Status Indicators
Power, WPS
Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), Apple AirPlay
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED
1 x audio - mini jack female
CSA, C-Tick, IC, FCC
Internal power supply
5.4 cm
4.2 cm
5.45 cm
81.2 g
10 - 90% (non-condensing)
