D-Link DBA-1210P AC1300 Wave2 Nuclias Access Point
Quicklinx: F9GHWS00 Mfr#: DBA-1210P
  • IEEE 802.11n
£134.61 ex VAT
£161.53 inc VAT
The DBA-1210P Business Cloud Wave 2 access point is designed specifically for enterprise environments. With new generation 802.11ac dual-band concurrent 2.4 GHz and 5.0 GHz radios, the DBA-1210P offers high combined data rates to wireless clients allowing for lightning-fast access to bandwidth intensive applications such as data, voice, and video. The DBA-1210P is meant to be deployed as a pre-managed, zero configuration access point controlled through the D-Link Business Cloud, allowing network administrators to spend more time on providing reliable connectivity and services and less time managing devices.
  • Hassle-free management with D-Link Business Cloud
    Designed to be managed through the D-Link Business Cloud, the DBA-1210P is easily set up with the help of D-Link's Business Cloud's intuitive browser-based or mobile app interface. Centralized cloud management allows for zero-touch provisioning, effectively eliminating the need for on-site support, and allowing for plug-and-connect installation. The DBA-1210P will connect to the D-Link Business Cloud to retrieve its configuration settings, meaning it can even be deployed at a remote location without an on-site network administrator. Using the intuitive cloud interface, businesses can easily organize their wireless network, manage multiple APs simultaneously, and monitor live network statistics.
  • Fast and efficient wireless AC Wave 2 performance
    The DBA-1210P delivers reliable, high-speed wireless AC Wave 2 performance with maximum wireless signal rates of up to 1.2 Gbps. Load-balancing optimization means that there is no need for the dedicated hardware and RF expertise typically required to tune a wireless network. The D-Link Business Cloud tunes the DBA-1210P's channel selection, transmit power, and max client connections for optimal performance under the most challenging RF conditions.
  • Enterprise-ready security
    To help maintain a secure wireless network, the DBA-1210P supports both Personal and Enterprise versions of WPA and WPA2 (802.11i), with support for RADIUS server backend and a cloud-managed local server. This access point also includes MAC address filtering, wireless LAN segmentation, SSID broadcast disable, rogue AP detection, and wireless broadcast scheduling to further protect your wireless network. The DBA-1210P includes support for up to 8 virtual access points (VAPs) per band for implementing multiple SSIDs to further help segment users on the network. It also includes a wireless client isolation mechanism, which limits direct client-to-client communication.
  • Versatile access point functionality
    The DBA-1210P allows network administrators to deploy a highly manageable and extremely robust wireless network with optimal wireless coverage. The DBA-1210P can be ceiling mounted, wall mounted, or placed on a desktop to meet any wireless demands. For advanced installations, the DBA-1210P has integrated IEEE 802.3af Power over Ethernet (PoE) support, allowing this device to be installed in areas where power outlets are not readily available.
D-Link Business Cloud Wave 2 DBA-1210P - radio access point - Wi-Fi 5
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz, 5 GHz
Virtual access points: 8
17 cm x 17 cm x 2.8 cm
Radio access point
17 cm
17 cm
2.8 cm
External
Wireless
Data Transfer Rate
1200 Mbps
Frequency Band
2.4 GHz, 5 GHz
Wi-Fi Rating
AC1200
Status Indicators
Power, status
Load balancing, MAC address filtering, Network Access Protection (NAP), rogue access point detection, Captive Portal, band steering, Energy-Efficient Ethernet (EEE), SSID isolation, ARP spoofing, 2x2 MIMO technology, Station Isolation, Guest Isolation, WLAN partition
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
Authentication Method
RADIUS
IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac Wave 2
Aerial
Antenna
Internal
1 x 1000Base-T (PoE) - RJ-45 - 12 W
MTBF
30,000 hours
FCC Class B certified, IC Class B, UL
External power adapter
12 Watt
10 - 90% (non-condensing)
Type: Radio access point
Connectivity: Wireless
Speed: 1200Mbps
Protocol: IEEE 802.11a
Protocol: IEEE 802.11n
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11ac Wave 2
Brand: D-Link
