D-Link's DXS-3600 Series Top-of-Rack 10 Gigabit Stackable Managed Switch consists of compact, high-performance switches that feature 10 Gigabit Ethernet switching, routing, and very low latency.
Data center features
Data Center Bridging (DCB) is an essential set of enhancements to Ethernet for networking in data center environments. The DXS-3600 switches support several core components of Data Center Bridging (DCB) such as IEEE 802.1Qbb, IEEE 802.1Qaz, and IEEE 802.1Qau. IEEE 802.1Qbb (Priority Based Flow Control) provides flow control to ensure there is no data loss during network congestion. IEEE 802.1Qaz (Enhanced Transmission Selection) manages the allocation of bandwidth amongst different traffic classes. IEEE 802.1Qau (Congestion Notification) provides congestion management for data flows within network domains to avoid congestion. The DXS-3600 switches also support cut-through switching, which reduces latency in transmitting data in a network. -
Energy efficient
The DXS-3600 switches allow users to change the airflow by using different power and fan module sets. Selectable front-to-back or back-to-front airflow maximizes air cooling to provide more effective cooling throughout rack systems in data centers, where the switches are used, compared to side-to-side airflow. The switches also feature built-in smart fans; internal heat sensors monitor and detect temperature change, and react accordingly by utilizing different fan speeds for different temperatures. At lower temperatures, the fans will run slower and reduce the switch's power consumption and noise.
- D-Link Data Center 10GbE Top-of-Rack Switch DXS-3600 - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- 10 Gigabit Ethernet
- Ports
- 24 x 10 Gigabit SFP+
- Performance
- Switching capacity: 960 Gbps
- Capacity
- IGMP groups: 4000
- MAC Address Table Size
- 128K entries
- Jumbo Frame Support
- 12KB
- Routing Protocol
- IGMPv2, IGMP, IGMPv3
- Remote Management Protocol
- SNMP, RMON, Telnet, HTTP, SSH, CLI
- Flow control, DoS attack prevention, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, ACL support, QoS, Safeguard Engine, LLDP support, Port Security, DCB
- IEEE 802.1p, IEEE 802.1w, IEEE 802.1s, IEEE 802.1Qbb, IEEE 802.1Qaz
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- 44 cm x 50.6 cm x 4.4 cm
- 9.8 kg
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Ports
- Performance
- Capacity
- IGMP groups: 4000
- 128K entries
- 12KB
- Max Units In A Stack
- 4
- Routing Protocol
- Encryption Algorithm
- SSL
- Authentication Method
- RADIUS, TACACS+
- Status Indicators
- Port transmission speed, power, link/activity, fan, console
- 24 x 10Gb Ethernet - RJ-45 , 1 x management RJ-45
- Expansion Slots
- 1 (total) / 1 (free) x Expansion Slot , 1 (total) / 1 (free) x SD Memory Card
- Installed Modules Qty (Max)
- 0 (installed) / 1 (max)
- Power Device
- Internal power supply - hot-plug
- Installed Qty
- 1
- Max Supported Qty
- 2
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Voltage Required
- VCCI, C-Tick, cUL, CB, IC, FCC, LVD
- Software Included
- Standard Image (SI) Software
- 44 cm
- 50.6 cm
- 4.4 cm
- 9.8 kg
- 0 °C
- 45 °C
- 0 - 95%
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 0 - 95%
D-Link DEM-311GT 1-Port Mini GBIC SX Multi Mode Fiber Transceiver | In Stock | £24.00 |
D-Link SFP+ Direct Attach Stacking Cable, 1M | In Stock | £173.05 |
D-Link 1-Port Mini GBIC Module for 1000BaseLX (LC Duplex) | In Stock | £31.73 |
