D-Link D-Link 24-ports 10Gigabit SFP+ Layer 3 Data Center Switch
Quicklinx: 82N6WS00 Mfr#: DXS-3600-32S/SI
Type: 10 Gigabit Ethernet
Ports: 24
Data Transfer Rate: 10Gbps
Managed: Yes
POE: No
£4,786.18 ex VAT
£5,743.41 inc VAT
D-Link's DXS-3600 Series Top-of-Rack 10 Gigabit Stackable Managed Switch consists of compact, high-performance switches that feature 10 Gigabit Ethernet switching, routing, and very low latency.
  • Data center features
    Data Center Bridging (DCB) is an essential set of enhancements to Ethernet for networking in data center environments. The DXS-3600 switches support several core components of Data Center Bridging (DCB) such as IEEE 802.1Qbb, IEEE 802.1Qaz, and IEEE 802.1Qau. IEEE 802.1Qbb (Priority Based Flow Control) provides flow control to ensure there is no data loss during network congestion. IEEE 802.1Qaz (Enhanced Transmission Selection) manages the allocation of bandwidth amongst different traffic classes. IEEE 802.1Qau (Congestion Notification) provides congestion management for data flows within network domains to avoid congestion. The DXS-3600 switches also support cut-through switching, which reduces latency in transmitting data in a network.
  • Energy efficient
    The DXS-3600 switches allow users to change the airflow by using different power and fan module sets. Selectable front-to-back or back-to-front airflow maximizes air cooling to provide more effective cooling throughout rack systems in data centers, where the switches are used, compared to side-to-side airflow. The switches also feature built-in smart fans; internal heat sensors monitor and detect temperature change, and react accordingly by utilizing different fan speeds for different temperatures. At lower temperatures, the fans will run slower and reduce the switch's power consumption and noise.
D-Link Data Center 10GbE Top-of-Rack Switch DXS-3600 - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
24 x 10 Gigabit SFP+
Performance
Switching capacity: 960 Gbps
IGMP groups: 4000
MAC Address Table Size
128K entries
Jumbo Frame Support
12KB
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP, RMON, Telnet, HTTP, SSH, CLI
Flow control, DoS attack prevention, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, ACL support, QoS, Safeguard Engine, LLDP support, Port Security, DCB
IEEE 802.1p, IEEE 802.1w, IEEE 802.1s, IEEE 802.1Qbb, IEEE 802.1Qaz
Power Redundancy
Optional
44 cm x 50.6 cm x 4.4 cm
9.8 kg
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
Performance
IGMP groups: 4000
128K entries
Jumbo Frame Support
12KB
Max Units In A Stack
4
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+
Status Indicators
Port transmission speed, power, link/activity, fan, console
24 x 10Gb Ethernet - RJ-45 , 1 x management RJ-45
Expansion Slots
1 (total) / 1 (free) x Expansion Slot , 1 (total) / 1 (free) x SD Memory Card
Installed Modules Qty (Max)
0 (installed) / 1 (max)
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
VCCI, C-Tick, cUL, CB, IC, FCC, LVD
Software Included
Standard Image (SI) Software
44 cm
50.6 cm
4.4 cm
9.8 kg
45 °C
0 - 95%
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95%
82N6 D-Link DEM-311GT 1-Port Mini GBIC SX Multi Mode Fiber Transceiver In Stock £20.13
82N6 D-Link 1-Port Mini GBIC Module for 1000BaseLX (LC Duplex) In Stock £32.75
Ports: 24
Managed: Yes
POE: No
Brand: D-Link
Price Range Ex VAT: £1500+
