Deploy this easy-to-install, high performance 5G/LTE outdoor CPE device. Equipped with a rugged IP67 weather-resistant housing, and flexible deployment options, it's ideal for both large-scale and individual deployments.
                High-speed 5G Internet with dual-modeConnect with next-generation 5G speeds of up to 4 Gbps and experience lightning-fast downloads, lower latency and reduced congestion. It features x6 built-in powerful 5G/LTE D-Link antennas, and the DWP-1010 also supports fallback from 5G to LTE so you'll always be connected.
                Withstands the weatherBuilt with a rugged IP67 weather-resistant housing to help protect the DWP-1010 from extreme weather and provide clear reception, so you can continue to receive the best connectivity possible - come rain or shine.
                Simple installation with Power over Ethernet (PoE)Comes with a 2.5 Gbps Ethernet LAN port with support for PoE, allowing a single Ethernet cable to carry both data and power to a device. No need to run extra power lines, no added hassle when configuring your hardwiring, and no more cable clutter.
- D-Link DWP 1010 - Outdoor 5G Kit - wireless cellular modem - 5G LTE
- Wireless cellular modem
- Bundled with
- M15 router
- Form Factor
- External
- Localisation
- United Kingdom
- Max Transfer Rate
- 1 Gbps
- Line Coding Format
- 1024 QAM, OFDMA
- Mobile Communication Protocol
- 5G NR, LTE, LTE Advanced Cat 19
- Mobile Band
- 5G n1/n3/n5/n7/n8/n20/n28/n38/n40/n41/n75/n76/n77/n78 LTE B1/B3/B5/B7/B8/B20/B28/B32/B38/B40/B41/B42/B43
- Networking
- IEEE 802.3i, IEEE 802.3u, IEEE 802.3at - 1 Gbps
- 10.54 cm x 14.48 cm x 21.04 cm
- 760 g
- Bundled with
- M15 router
- Form Factor
- External
- Localisation
- United Kingdom
Modem
- Connectivity Technology
- Wireless
- Processor
- Qualcomm SDX62
- Max Transfer Rate
- 1 Gbps
- Mobile Band
- 1024 QAM, OFDMA
- Antenna
- Internal
- Antenna Qty
- 5
- Wireless
- Data Link Protocol
- Data Transfer Rate
- 1 Gbps
- MU-MIMO technology, reset button, 6KV Surge protection, Denial of Service (DoS), Stateful Packet Inspection (SPI), anti-spoofing protection, IP address filtering, MAC address filtering, DMZ support, Wireless Mesh support, Quality of Service (QoS), LED status indicator
- IEEE 802.3at, IEEE 802.3i, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- 1 x 1000Base-T (PoE) - RJ-45
- SIM Card Supported
- Micro-SIM x 1
- Encryption Algorithm
- WPA3, WPA2-Personal, WPA3-Personal, WPA-Personal
- IP67, Plug and Play, IEC 62443-4-1, FCC
- 10.54 cm
- 14.48 cm
- 21.04 cm
- 760 g
- -30 °C
- 50 °C
- 10 - 95% (non-condensing)
