D-Link Bundle Kit DWP-1010/ODU & M15/IDU
Quicklinx: J7JFWS00 Mfr#: DWP-1010/KT/B
£276.67 ex VAT
£332.00 inc VAT
Deploy this easy-to-install, high performance 5G/LTE outdoor CPE device. Equipped with a rugged IP67 weather-resistant housing, and flexible deployment options, it's ideal for both large-scale and individual deployments.
  • High-speed 5G Internet with dual-mode
    Connect with next-generation 5G speeds of up to 4 Gbps and experience lightning-fast downloads, lower latency and reduced congestion. It features x6 built-in powerful 5G/LTE D-Link antennas, and the DWP-1010 also supports fallback from 5G to LTE so you'll always be connected.
  • Withstands the weather
    Built with a rugged IP67 weather-resistant housing to help protect the DWP-1010 from extreme weather and provide clear reception, so you can continue to receive the best connectivity possible - come rain or shine.
  • Simple installation with Power over Ethernet (PoE)
    Comes with a 2.5 Gbps Ethernet LAN port with support for PoE, allowing a single Ethernet cable to carry both data and power to a device. No need to run extra power lines, no added hassle when configuring your hardwiring, and no more cable clutter.
D-Link DWP 1010 - Outdoor 5G Kit - wireless cellular modem - 5G LTE
Wireless cellular modem
Bundled with
M15 router
External
United Kingdom
Max Transfer Rate
1 Gbps
Line Coding Format
1024 QAM, OFDMA
Mobile Communication Protocol
5G NR, LTE, LTE Advanced Cat 19
Mobile Band
5G n1/n3/n5/n7/n8/n20/n28/n38/n40/n41/n75/n76/n77/n78 LTE B1/B3/B5/B7/B8/B20/B28/B32/B38/B40/B41/B42/B43
IEEE 802.3i, IEEE 802.3u, IEEE 802.3at - 1 Gbps
10.54 cm x 14.48 cm x 21.04 cm
760 g
Bundled with
M15 router
External
United Kingdom
Modem
Wireless
Qualcomm SDX62
Max Transfer Rate
1 Gbps
Mobile Band
Line Coding Format
1024 QAM, OFDMA
Antenna
Internal
Antenna Qty
5
Wireless
Data Transfer Rate
1 Gbps
MU-MIMO technology, reset button, 6KV Surge protection, Denial of Service (DoS), Stateful Packet Inspection (SPI), anti-spoofing protection, IP address filtering, MAC address filtering, DMZ support, Wireless Mesh support, Quality of Service (QoS), LED status indicator
IEEE 802.3at, IEEE 802.3i, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
1 x 1000Base-T (PoE) - RJ-45
SIM Card Supported
Micro-SIM x 1
Encryption Algorithm
WPA3, WPA2-Personal, WPA3-Personal, WPA-Personal
IP67, Plug and Play, IEC 62443-4-1, FCC
10.54 cm
14.48 cm
21.04 cm
760 g
-30 °C
50 °C
10 - 95% (non-condensing)
Brand: D-Link
