D-Link BT ADSL2+ Wireless G Router with 4 Port 10/100 Switch
Quicklinx: 5HPBWS00 Mfr#: DSL-2640R/UK
  • Wi-Fi CERTIFIED
The DSL-2640R wireless ADSL router is an affordable high performance ADSL router fit for homes and small offices. With integrated ADSL2/2+ supporting up to 24Mbps download speed, 802.11g wireless LAN, firewall protection, Quality of Service (QoS) and 4-port switch, this router provides all the essentials that a home or small office needs to establish a secure and high-speed remote link to the outside world.
  • Ultimate Internet connection
  • Affordable high-speed connection for homes and small offices
    Designed as a very affordable high performance ADSL router for home and SOHO users, the DSL-2640R provides not only low-cost, high-speed Internet connection, but also the security and Quality of Service (QoS) required by users in today's high risk and versatile Internet environments.
  • Ready wired and wireless LAN connection
    The DSL-2640R provides an integrated 802.11g WLAN interface supporting wireless speeds of up to 54Mbps and interoperability with 802.11b wireless devices on the 2.4GHz frequency band. It also provides four 10/100Mbps Ethernet switch ports for ready workstations connection. These built-in functions save you the cost and trouble of installing a separate wireless access point and an Ethernet switch.
  • Firewall protection and QoS
    Security features prevents unauthorized access to the home and office network from Internet intruders. The router provides firewall security using Stateful Packet Inspection (SPI) and Denial of Service (Dos) attack protection. SPI inspects the contents of all incoming packet headers before deciding what packets are allowed to pass through. Router access control is provided with packet filtering based on port and source/destination MAC/IP addresses. For Quality of Service (QoS), the router supports multiple priority queues to enable a group of home or office users to experience the benefit of smooth network connection of inbound and outbound data without concern of traffic congestion.
D-Link DSL-2640R Wireless G ADSL2+ 4-Port Modem Router - wireless router - DSL - 802.11b/g - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Frequency Band
2.4 GHz
Data Transfer Rate
54 Mbps
Network / Transport Protocol
TCP/IP, PPTP, PPPoE, PPPoA
Routing Protocol
Static IP routing
Remote Management Protocol
Telnet, HTTP
Firewall protection, auto-sensing per device, DHCP support, NAT support, auto-uplink (auto MDI/MDI-X), traffic shaping, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, packet filtering, ALG support, DiffServ support, E-mail alert, MAC address filtering, VPN passthrough, parental control, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, UPnP
United Kingdom
2 years warranty
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
54 Mbps
Routing Protocol
Static IP routing
Telnet, HTTP
Encryption Algorithm
WPA-PSK
Authentication Method
Radio Service Set ID (SSID)
Status Indicators
Link activity, power
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
ADSL, ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.4 (G.lite.bis), ITU G.992.1 (G.DMT) Annex A, ITU G.992.5 Annex A
Max Transfer Rate
24 Mbps
LAN : 4 x 10Base-T/100Base-TX - RJ-45 , WAN : 1 x ADSL2+ - RJ-11 , Management : 1 x console
Aerial
Aerial
External detachable
Antenna Qty
1
Gain Level
2 dBi
Power adapter - external
EN 60950, UL 1950, IEC 60950, EN 300.328, FCC Part 15 B, FCC Part 68, FCC Part 15 C
United Kingdom
2 years warranty
Service & Support Details
5 - 95%
Resources
The following resources are available for the D-Link BT ADSL2+ Wireless G Router with 4 Port 10/100 Switch
