D-Link Baby Monitor HD 360
Quicklinx: B8FZWS00 Mfr#: DCS-855L
Watch over your child anytime, anywhere with the DCS-855L EyeOn Baby Monitor HD 360. Pan/tilt functionality lets you move the camera remotely; monitoring an entire playroom with ease from your mobile device! With night vision, temperature monitoring, sound and motion detection, 2-way audio, notifications and more, the DCS-855L keeps you connected to your family.
  • Peace of mind, anywhere, anytime
    The Pan/Tilt Baby Camera is specially designed to make it easy for you to care for your baby. Its versatile all-day monitoring turns on night vision automatically when it gets dark, giving you a clear picture day or night so you can keep an eye on things anytime. Receive notifications when sound, motion, or a temperature change is detected. Not only can you see and hear your infant, but you can also comfort them with one of five gentle lullabies or even the sound of your voice through two-way audio. It's perfect for use in the home, or even when you're away. It's mydlink-enabled, which means that you can access your camera remotely over the Internet on your PC or mobile device. Check on your baby while in the office, or check on the day's events by playing back videos recorded to an installed microSD card.
  • Pan/tilt for corner to corner coverage
    Unlike most baby monitors, the Pan/Tilt Baby Camera can pivot up, down, left, and right at your command, giving you the ability to watch over a large room effortlessly. Whisper quiet motors let you move the camera's view without waking your sleeping child.
  • Perfectly portable for instant monitoring anywhere
    You can take the Pan/Tilt Baby Camera with you when traveling with your child, even when there is no available Internet connection. Just connect your mobile device to the Pan/Tilt Baby Camera's wireless network for instant local monitoring, making it perfect for family vacations or just visiting friends. You can even connect it to an external USB battery for total portability!
  • Super simple to use
    Getting started is a snap; the free mydlink Baby App for iPhone, iPad, and Android mobile devices not only guides you step by step through the setup process, but also gives you an easy to use interface for all the advanced features of the Pan/Tilt Baby Camera. Check on your baby at a glance, pinch to zoom in and out with ease, or play one of five gentle lullabies to soothe your child. You can even take snapshots and video clips and save them directly to your mobile device!
D-Link DCS-855L - network surveillance camera
Network surveillance camera - pan / tilt
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
10.916 cm x 11.416 cm x 13.13 cm
396 g
Wireless
Camera
Colour - Day&Night
Max Resolution
1280 x 720
Optical Sensor Type
CMOS - 1/4"
Minimum Illumination
0 lux - IR
Focal Length Control
Fixed focal
Focal Length
3.3 mm
Focus Adjustment
Manual (min distance 200 mm)
Lens Iris
F/2.2
Panning Range (degree)
-170 to +170
Tilting Range (degree)
-25 to +95
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage
DC 5 V
Motion sensor, date/time stamp, USB powered, light sensor, infrared cut filter, microSDHC card slot, temperature sensor, noise detection, reset button, pre-installed lullabies
1-year warranty
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Audio Support
Wireless
10.916 cm
11.416 cm
13.13 cm
396 g
Camera
Colour - Day&Night - pan / tilt
Digital Video Format
H.264
Max Digital Video Resolution
1280 x 720
Digital Zoom
4
0 lux - IR
Infrared LEDs
Infrared Distance
5 m
Video Capture
1280 x 720 @ 15 fps , 640 x 352 @ 30 fps
Supported Image Formats
JPEG
Image Sensor
CMOS 1/4"
Lens Construction
Fixed focal
Focal Length
3.3 mm
Lens Iris
F/2.2
Focus Adjustment
Manual
Min Focus Distance
200 mm
Horizontal Field of View (degree)
70.4
Vertical Field of View (degree)
43
Panning
Range (degree)
-170 to +170
Tilting
Range (degree)
-25 to +95
Network Interface
Network Protocols
DDNS, DHCP, DNS, HTTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, HTTPS, UPnP, IPv4, RTCP
Mounting bracket, wall mount kit
FCC Class B certified, C-Tick, ICES
Power Requirements
DC 5 V - 2 A
Power adapter - external AC 120/230 V (50/60 Hz) 7.5 Watt
Apple MacOS X 10.6 or later, Microsoft Windows Vista / 7 / 8, Android 4.0 or later, Apple iOS 5.1.1 or later
Limited warranty - 1 year
Relative Humidity (operating)
