D-Link AX3600 Wi-Fi 6 Dual-Band PoE Access Point
Quicklinx: J7JQWS00 Mfr#: DAP-X2850
£167.78 ex VAT
£201.33 inc VAT
The Wi-Fi 6 ready DAP-X2850 is on hand to provide unbeatable speeds, greatly increased capacity and interference-free coverage throughout businesses, paired with the easy management of Connect.
  • Wi-Fi that turbo boosts business performance
    With the DAP-X2850 by your side, it's all systems go. It is fully prepared to handle all day-to-day demands of busy SMBs. Equipped with Wi-Fi 6, there are massive performance improvements, as well as all the features of 11ac now available for the 2.4 GHz band too.
  • Take a load off and let your AP do the hard work
    The DAP-X2850's Load Balancing feature spreads the work load between two or more Access Points to get optimal resource utilization, throughput and response time, while Airtime Fairness helps distribute equal amounts of air time to each connected client. Band Steering auto-connects devices such as smart phones and tablets to the higher-capacity 5 GHz band while allowing devices 2.4 GHz-ready to remain. The result is a steady, consistent connection for each user - the perfect balancing act.
  • No-wait Wi-Fi even at peak time with MU-MIMO
    Equipped with the latest 802.11ax MU-MIMO technology and 3600 Mbps throughput, delivering exceptional connectivity to more users and devices just got a lot easier. Your network will not balk, even at the busiest of times.
  • Your network, future proofed
    Equipped with a 2.5 Gigabit Ethernet Port, the DAP-X2850 delivers exceptional multi-gigabit performance to support demand for better and faster Wi-Fi. Compatibility with standard 802.3at PoE+ is ideal for flexible deployment. No need to run extra power lines, no added hassle when configuring your hardwiring and no more cable clutter. Perfect for advanced installations in areas where power outlets are not readily available.
  • Multi-mode makes the most of your network capabilities
    In order to achieve optimal network performance, the DAP-X2850 has several operational modes tailored to best fit the individual needs of your network. Access Point, Wireless Client, WDS (Wireless Distribution System), and WDS with Access Point modes allow for flexible, customizable deployment whatever your requirements.
  • Complete control over your network's access
    Complete control comes as standard with the DAP-X2850. Combined with the Nuclias Connect Software, a variety of the latest in network security and management tools are at your fingertips. You can rest assured that the best of the best are hard at work keeping your network protected and hitch free.
Nuclias Connect DAP-X2850 - radio access point - Wi-Fi 6
Radio access point
Wall / ceiling mountable - indoor
Ports Qty
2
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 802.11ax
Frequency Band
2.4 GHz, 5 GHz
Performance
Maximum data rate (2.4 GHz): 1147 Mbps , Maximum data rate (5 GHz): 2400 Mbps
Power Over Ethernet (PoE) Supported
PoE+
21.24 cm x 21.24 cm x 4.67 cm
763.8 g
Radio access point
Ruggedized Design
Indoor
21.24 cm
21.24 cm
4.67 cm
763.8 g
Ports Qty
2
Wireless
Network / Transport Protocol
POP3, HTTP, Telnet
Remote Management Protocol
Telnet, HTTP, SSH, LDAP, RADIUS
Frequency Band
2.4 GHz, 5 GHz
Performance
Wi-Fi Rating
AX3600
Status Indicators
Power, status
Wireless Distribution System (WDS) support, reset button, Traffic Control, Captive Portal, 802.1x authentication, MU-MIMO technology, band steering, Airtime Fairness, Energy-Efficient Ethernet (EEE), Target Wait Time (TWT)
Encryption Algorithm
128-bit WEP, 64-bit WEP, SSL, WPA-Enterprise, WPA2-Enterprise, WPA3-Enterprise, WPA3-Personal, WPA2-Personal, WPA-Personal
Authentication Method
Secure Shell (SSH), RADIUS, Radio Service Set ID (SSID), LDAP
IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
Aerial
Antenna
Internal
Antenna Qty
4
1 x 1000Base-T - RJ-45 , 1 x 1/2.5GBase-T (PoE+) - RJ-45 , 1 x console - RJ-45
MTBF
30,000 hour(s)
FCC
PoE+
19.44 Watt
10 - 90%
Brand: D-Link
