D-Link AX1800 Wi-Fi 6 Dual-Band PoE Access Point
Quicklinx: J7JPWS00 Mfr#: DAP-X2810
Hurry, only 2 left in stock!
£83.86 ex VAT
£100.63 inc VAT
The Wi-Fi 6 ready DAP-X2810 is on hand to provide unbeatable speeds, greatly increased capacity and interference-free coverage throughout businesses, paired with the easy management of Connect.
  • Wi-Fi 6 ready
    The DAP-X2810 is empowered with next generation Wi-Fi 6. Enhanced MU-MIMO with even more uplink and downlink streams serves more devices simultaneously. OFDMA dramatically increases transmission efficiency and 1024-QAM packs even more data, bringing unadulterated speed increases of a searing 25%.
  • Wi-Fi that turbo boosts business performance
    With the DAP-X2810 by your side, it's all systems go. It is fully prepared to handle all day-to-day demands of busy SMBs. Equipped with Wi-Fi 6, there are massive performance improvements, as well as all the features of 11ac now available for the 2.4 GHz band too.
  • Take a load off and let your AP do the hard work
    The DAP-X2810's Load Balancing feature spreads the work load between two or more Access Points to get optimal resource utilization, throughput and response time, while Airtime Fairness helps distribute equal amounts of air time to each connected client. Band Steering auto-connects devices such as smart phones and tablets to the higher-capacity 5 GHz band while allowing devices 2.4 GHz-ready to remain. The result is a steady, consistent connection for each user - the perfect balancing act.
  • No-wait Wi-Fi even at peak time with MU-MIMO
    Equipped with the latest 802.11ax MU-MIMO technology and 1800 Mbps throughput, delivering exceptional connectivity to more users and devices just got a lot easier. Your network will not balk, even at the busiest of times.
  • Multi-mode makes the most of your network capabilities
    In order to achieve optimal network performance, the DAP-X2810 has several operational modes tailored to best fit the individual needs of your network. Access Point, WDS (Wireless Distribution System), and WDS with Access Point modes allow for flexible, customizable deployment whatever your requirements.
Nuclias Connect DAP-X2810 - radio access point - Wi-Fi 6
Radio access point
Wall / ceiling mountable - indoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 802.11ax
Frequency Band
2.4 GHz, 5 GHz
Performance
Maximum data rate (2.4 GHz): 575 Mbps , Maximum data rate (5 GHz): 1200 Mbps
Power Over Ethernet (PoE) Supported
PoE
21.24 cm x 21.24 cm x 4.67 cm
763.8 g
Radio access point
Ruggedized Design
Indoor
21.24 cm
21.24 cm
4.67 cm
763.8 g
Wireless
Network / Transport Protocol
POP3, HTTP, Telnet
Remote Management Protocol
Telnet, HTTP, SSH, LDAP, RADIUS
Frequency Band
2.4 GHz, 5 GHz
Performance
Wi-Fi Rating
AX1800
Status Indicators
Power, status
Wireless Distribution System (WDS) support, reset button, Traffic Control, Captive Portal, 802.1x authentication, MU-MIMO technology, band steering, Airtime Fairness, Energy-Efficient Ethernet (EEE)
Encryption Algorithm
128-bit WEP, 64-bit WEP, SSL, WPA-Enterprise, WPA2-Enterprise, WPA3-Enterprise, WPA3-Personal, WPA2-Personal, WPA-Personal
Authentication Method
Secure Shell (SSH), RADIUS, Radio Service Set ID (SSID), LDAP
IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
Aerial
Antenna
Internal
Antenna Qty
4
1 x Ethernet 1000 (PoE) - RJ-45 , 1 x console - RJ-45
MTBF
30,000 hour(s)
FCC
PoE
19.44 Watt
10 - 90%
Brand: D-Link
