D-Link AirPlus G DWL-G700AP Access Point
Quicklinx: B8GRWS00 Mfr#: DWL-6700AP
Type: Radio access point
Connectivity: Wireless
Speed: 300Mbps
Protocol: IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Compatibility: PC
  • IEEE 802.11n
£163.46 ex VAT
£196.15 inc VAT
The DWL-6700AP has a sleek, weatherproof housing design with an embedded antenna so it can be easily mounted onto a pole or wall. Its ability to operate between -30°C to 50°C, protecting against exposure to heat, cold or rain makes this an ideal outdoor wireless access point.
  • Centrally manage your wireless network
    When working in conjunction with D-Link Unified Switch/Controllers, the DWL-6700AP can be centrally managed. This allows a large number of APs to be deployed and managed easily and efficiently. Once the APs are discovered by the switch/controller, the administrator can push specific configuration sets onto them rather than having to do so one by one. In addition, RF resource management and security are also managed centrally, thus allowing the administrator to preemptively identify potential deficiencies and weaknesses in the network.
  • Wi-Fi strength LEDs and remote reset button
    The 5 GHz signal strength LEDs provide simple indicators to display the signal strength of the WDS link, so administrators do not need to worry about aiming the direction of the signal at the opposite point, even if the two APs are one to two kilometers away from each other. Aside from the reset button (first reset button) on the DWL-6700AP, the PoE injector also supports a second reset button for remote setup.
  • Quality of service for increased connectivity
    The DWL-6700AP supports 802.1p Quality of Service (QoS) for enhanced throughput and better performance of time-sensitive traffic like VoIP and streaming DSCP. The DWL-6700AP is WMM-certified, so in the event of network congestion, time-sensitive traffic can be given priority ahead of other traffic. Furthermore, when a number of DWL-6700AP units are in close proximity to each other, an access point will refuse new association requests once its resources are fully utilized, allowing the association request to be picked up by a neighboring unit. This feature ensures that no single AP is overburdened while others nearby sit idle.
D-Link DWL-6700AP - radio access point
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE
28 cm x 11.5 cm x 5 cm
495 g
Radio access point
28 cm
11.5 cm
5 cm
495 g
External
Wireless
Data Transfer Rate
300 Mbps
Remote Management Protocol
HTTP, HTTPS, SSH
Frequency Band
2.4 GHz, 5 GHz
MAC address filtering, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), plastic housing, Virtual Access Points (VAP)
Encryption Algorithm
AES, TKIP, WPA, WPA2
IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
2
Directivity
Omni-directional
2 x 1000Base-T (PoE) - RJ-45
C-Tick, cUL, IC, FCC, AES, EN 301.893, TELEC, LVD, IP55, NCC, EN 300 328
PoE
-20 °C
50 °C
10 - 90% (non-condensing)
Speed: 300Mbps
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Brand: D-Link
Price Range Ex VAT: 150 - 300
