D-Link AirPlus G 802.11g Wireless LAN USB Adapter
Customer rating: 4.0* (Write a review)
Quicklinx: 3GD0WS00 Mfr#: DWL-G122
  • Wi-Fi CERTIFIED
D-Link, the industry pioneer in wireless networking, introduces the DWL-G122 Wireless USB Adapter, part of the AirPlus G family of 802.11g wireless networking devices.
Using the DWL-G122 Wireless USB Adapter, you can now enable 802.11g wireless connectivity for your PC using the convenience and speed of a USB 2.0 interface.
Featuring the latest in wireless technology, the DWL-G122 delivers incredibly fast performance and industry-wide compatibility.
By adhering to the 802.11g wireless standard, the DWL-G122 is capable of streaming video and transferring large files across a wireless network.
The DWL-G122 Wireless USB Adapter includes an easy-to-use configuration that discovers available wireless networks wherever you go. The utility can also create detailed connectivity profiles to save your most frequently used networks. You can also enable support for WPA and 802.1x, for better data encryption and user authentication.
The DWL-G122 is a Wireless USB 2.0 adapter that installs quickly and easily into any desktop or laptop PC with an available USB port. You can simply plug in the DWL-G122 to enjoy the freedom of wireless networking. When used with other D-Link AirPlus G products in their default configuration, the DWL-G122 automatically discovers and connects to the wireless network.
Like all other D-Link wireless adapters, the DWL-G122 Wireless USB Adapter can be used in peer-to-peer mode (ad-hoc) to directly connect to other 802.11b/g wirelessly enabled computers for direct file sharing, or in client mode (infrastructure) to connect with wireless access points or routers.
Network adapter
External
Interface (Bus) Type
Hi-Speed USB
2.3 cm x 7.5 mm x 0.6 cm
IEEE 802.11b, IEEE 802.11g
Data Transfer Rate
54 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED
2000 / XP
Microsoft Certification
Network adapter
External
Hi-Speed USB
2.3 cm
7.5 mm
0.6 cm
Wireless
Spread Spectrum Method
OFDM, DSSS
Data Transfer Rate
54 Mbps
Line Coding Format
CCK, BPSK, QPSK, OFDM
Frequency Band
2.4 GHz
Max Range Indoors
100 m
Max Range Open Space
400 m
Status Indicators
Link activity, power, link OK
Aerial
Antenna
Internal integrated
Directivity
Omni-directional
1 x Hi-Speed USB - 4 PIN USB Type A
1 x USB extension cable ( external ) - 1.5 m
Encryption Algorithm
128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2
Certified for Windows Vista
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
FCC Class B certified, CE, FCC Part 15
Software Included
Drivers & Utilities
Microsoft Windows 98SE/2000/ME/XP
Customer reviews
Write a review for the D-Link AirPlus G 802.11g Wireless LAN USB Adapter here!
Great Value
Reviewed by Les. Review Posted 29/03/2008
Absolutely brilliant piece of kit for the price .... it does exactly what it says on the box.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Good range
Reviewed by James. Review Posted 16/02/2007
Nice and cheap and has a very good range. Easy to install but easier to use if you just let windows do it for you.
The signal did tend to drop occasionally, but that could be due to many things.
The long USB cord allowed the device to be move around to get the best signal.
  • Overall 5*
  • Ease of use 4*
Compact, portable, easy to install and it works!
Reviewed by Anonymous Review Posted 11/09/2005
This is a breeze to install. It came bundled with a wireless ADSL modem/router/firewall (DSL-G604T) so I didn't actually pay the full price for it. The accompanying CD installed drivers on WinXP without trouble. It's currently working on a PC that's about 25ft away from the router, with two old walls between, and signal strength is strong to very strong in its present location. Recommended.
  • Overall 5*
  • Ease of use 5*
Read all 14 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
