The D-Link AC5300 Ultra Wi-Fi router delivers the outstanding performance customers are expecting today for the demanding tasks, like 4K video streaming, gaming and multiple device usage. It delivers breakthrough tri-band Wi-Fi technology with amazing combined wireless speeds. Thanks to 4x4 data streams, that can be combined through beamforming and MU-MIMO technology to increase reliability and range. The entire family can now enjoy 4K streaming and gaming on multiple devices without any lag.
The advanced Wi-Fi coverage
Eight high-performance external antennas and high-power amplifiers will deliver improved Wi-Fi range and signal stability throughout your home. You'll connect to your devices faster and no more dead zones. -
Multi-user MIMO (MU-MIMO)
The DIR-895L/R is designed to support MU-MIMO technology that allows multiple devices to get high-bandwidth Wi-Fi signal at the same time, distributing data more efficiently, giving you the fast Wi-Fi speeds in your home. You can stream HD media faster, transfer large files really fast and play lag-free gaming. -
More processing power
Want a powerful high-performance processor that can handle multiple tasks at incredible speeds? An excellent processor boosts multitasking computing power and improves throughput speeds for all of your applications. -
Improved user interface
Controlling your network by enabling parental controls, blocking unwanted devices, monitoring Internet activity and creating Wi-Fi guest networks is easier than ever with the advanced interface. -
Really fast wired performance
Connect a few wired devices and enjoy the optimal online experience for HD streaming and gaming.
- D-Link AC5300 Ultra - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 5332 Mbps
- PPTP, L2TP, IPSec
- Firewall protection, NAT support, Stateful Packet Inspection (SPI), content filtering, print server, MAC address filtering, IPv6 support, VPN passthrough, URL filtering, Zero Configuration Technology, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), Green Ethernet, reset button, DLNA Media Server, SharePort Technology, VPN Server, Guest Zone support, MU-MIMO technology, Advanced AC SmartBeam technology, SmartConnect Technology
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac
- Power
- AC 120/230 V (50/60 Hz)
- 26.272 cm x 41.773 cm x 14.96 cm
- System Requirements
- Apple MacOS X Lion 10.7, Microsoft Windows 7 / 8 / 8.1 / 10
- 1-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 5332 Mbps
- PPTP, L2TP, IPSec
- Encryption Algorithm
- WPA, WPA2
- Wi-Fi Rating
- AC5300
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac, FCC Class B certified, IPv6 Ready
- Processor
- 1.4 GHz
- Built-in Devices
- Led panel
- Status Indicators
- Power, wireless, link/activity, USB
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB 3.0: 1 x 9 pin USB Type A
Aerial
- Aerial
- External detachable
- Antenna Qty
- 8
- Power Device
- External power adapter
- Voltage Required
- Cables Included
- 1 x network cable
- OS Required
- 26.272 cm
- 41.773 cm
- 14.96 cm
- Limited warranty - parts and labour - 1 year
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
