D-Link AC1200 GB Router
Quicklinx: BKJ6WS00 Mfr#: DIR-842
  • IEEE 802.11n
The DIR-842 Wireless AC1200 Dual Band Gigabit Router combines the latest high-speed 802.11ac dual-band Wi-Fi with Gigabit Ethernet ports to provide a seamless networking experience. The DIR-842's advanced security features keep data safe from unwanted network intruders, whilst the increased range and reliability of Wireless AC technology allows you to stay connected even under heavy network utilization or in rooms that have bad wireless signal.
  • Enhanced connectivity
    With dual-band support for 2.4 GHz and 5 GHz, the D-Link DIR-842 ensures a stable and faster wireless connection. The inclusion of both Ethernet and wireless connectivity options caters to a wide range of network preferences and setups.
  • Robust security
    The D-Link DIR-842 comes equipped with WPA and WPA2 encryption algorithms, enhancing the security of your network. With features like Wi-Fi Protected Setup (WPS), maintaining a secure connection becomes effortless and straightforward.
  • High-speed performance
    Featuring 2T2R MIMO technology and support for the 802.11ac wireless standard, this router delivers high-speed Internet access, making it ideal for streaming, gaming, and downloading large files.
  • Versatile management
    Remote management is simplified with HTTP protocol support, allowing for easy configuration and monitoring of the network. The router's dynamic and static IP modes provide flexible options for various network requirements.
  • Efficient operation
    Designed for optimal performance, the D-Link DIR-842 operates within a wide temperature range and maintains its efficiency even in high humidity, ensuring reliable operation in various environments.
D-Link DIR-842 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Network / Transport Protocol
PPTP, L2TP, PPPoE, DHCP, DNS, DDNS
Remote Management Protocol
HTTP
ISP, IPv6 support, WPS, static IP mode, 2T2R MIMO technology, IPv4 support, dynamic IP mode
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
AC 120/230 V (50 - 60 Hz)
18.994 cm x 13.297 cm x 3.81 cm
288 g
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
HTTP
Encryption Algorithm
WPA, WPA2
Authentication Method
Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, CCC, FCC, RoHS
Status Indicators
Power, WAN, LAN, wireless, WPS, Internet
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
External detachable
Antenna Qty
4
External power adapter
1 x network cable
18.994 cm
13.297 cm
3.81 cm
288 g
10 - 90% (non-condensing)
