D-Link 802.11 wireless Fast Ethernet LAN PoE Port
Quicklinx: C554WS00 Mfr#: DAP-2230
  • IEEE 802.11n
The DAP-2230 Wireless N PoE Access Point allows businesses to create a secure and manageable wireless network. Multiple operational modes, network management tools and security features gives network administrators more flexible deployment options. The DAP-2230 can be ceiling mounted, wall mounted or placed on a desktop to meet any wireless demands.
  • Faster wireless networking
    The DAP-2230 provides an up to 300 Mbps wireless connection with other 802.11n wireless clients. This capability allows users to participate in real-time activities online, such as video streaming, online gaming, and real-time audio.
  • Four different operation modes
    Capable of operating in one of four different operation modes to meet your wireless networking needs: Access Point, WDS with AP, WDS, and Wireless Client.
  • Power over Ethernet
    The DAP-2230 supports IEEE 802.3af PoE (Power over Ethernet) which enables it to be supplied with power over an Ethernet cable or IEEE 802.3af PoE switch.
  • Convenient installation
    The DAP-2230 features a wall mount in the rear for easy setup on walls.
D-Link DAP-2230 Wireless N PoE Access Point - radio access point - Wi-Fi
Radio access point
External
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Wall mounting kit
Power Over Ethernet (PoE) Supported
PoE
12.9 cm x 12.9 cm x 2.9 cm
101.4 g
Radio access point
12.9 cm
12.9 cm
2.9 cm
101.4 g
External
Wireless
Network / Transport Protocol
SMTP, DHCP
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, HTTP, HTTPS
Frequency Band
2.4 GHz
Status Indicators
Status
LDAP support, MAC address filtering, Wireless Distribution System (WDS) support, reset button, Wireless Client Mode, Traffic Control, security lock slot (cable lock sold separately)
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, SSL, TLS, TKIP, WPA, WPA2, WPA-Enterprise, WPA2-Enterprise
Authentication Method
RADIUS, Radio Service Set ID (SSID), LDAP
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
Antenna
Internal
Gain Level
3 dBi
1 x 100Base-TX (PoE) - RJ-45
Wall mounting kit
UL, IC, FCC, TLS
PoE
External power adapter
16.8 Watt
0 - 90% (non-condensing)
C554 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
C554 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.47
