D-Link 8-Port PoE Gigabit Smart Managed Switch
Quicklinx: J7KGWS00 Mfr#: DGS-1100-08PV2/B
14 In Stock
£60.96 ex VAT
£73.15 inc VAT
The D-Link DGS 1100-08PV2 switch is engineered to meet the demands of modern networks, offering robust performance, enhanced connectivity, and advanced network management features. With its 16 Gbps switching capacity and 11.9 Mpps forwarding performance, it efficiently manages network traffic, ensuring smooth and reliable data transmission. The switch features 8 PoE ports, providing a convenient and cost-effective solution for powering IP cameras, VoIP phones, and other PoE devices, while its total PoE budget of 64 W accommodates various deployment scenarios.
Designed for durability and reliability, the D-Link DGS 1100-08PV2 operates within a wide range of environmental conditions and boasts a fanless design for silent operation, making it ideal for noise-sensitive environments. Its comprehensive suite of network management features, including VLAN support and Quality of Service (QoS), allows for efficient traffic prioritization and enhanced network security. Additionally, the inclusion of D-Link Green technology underscores a commitment to energy efficiency, automatically optimizing power usage and contributing to significant energy savings. Whether for small businesses or enterprise applications, this switch is a versatile and eco-friendly solution for modern networking needs.
D-Link DGS 1100-08PV2 - switch - 8 ports - smart
Switch - 8 ports - smart
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE)
Power Over Ethernet (PoE)
PoE
PoE Budget
64 W
Performance
Switching capacity: 16 Gbps , Forwarding performance: 11.9 Mpps
MAC Address Table Size
4K entries
Jumbo Frame Support
9216 bytes
Remote Management Protocol
HTTP
Flow control, Layer 2 switching, auto-negotiation, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, QoS, Cable Diagnostics Function, bandwidth control, D-Link Green Technology, fanless, 1.5MB packet buffer, WRR, loopback detection, DSCP based QoS
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
(50/60 Hz)
17.1 cm x 9.78 cm x 2.86 cm
433 g
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE
PoE Budget
64 W
Performance
4K entries
Jumbo Frame Support
9216 bytes
HTTP
Flash Memory
2 MB
8 x 1000Base-T RJ-45 PoE - 30 W
External power adapter
(50/60 Hz)
77.9 Watt
Power Consumption Stand by
2 Watt
MTBF
786,841 hours
FCC Class B certified, BSMI, cUL, CB, LVD, VCCI Class B, RoHS 10
Software Included
D-Link Network Assistant
17.1 cm
9.78 cm
2.86 cm
433 g
Limited warranty - lifetime
0 - 90% RH (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% RH (non-condensing)
Brand: D-Link
