D-Link 8-Port PoE Gigabit Smart Managed Switch
Quicklinx: J7KGWS00 Mfr#: DGS-1100-08PV2/B
17 In Stock
£58.74 ex VAT
£70.48 inc VAT
The D-Link DGS 1100-08PV2 switch is engineered to meet the demands of modern networks, offering robust performance, enhanced connectivity, and advanced network management features. With its 16 Gbps switching capacity and 11.9 Mpps forwarding performance, it efficiently manages network traffic, ensuring smooth and reliable data transmission. The switch features 8 PoE ports, providing a convenient and cost-effective solution for powering IP cameras, VoIP phones, and other PoE devices, while its total PoE budget of 64 W accommodates various deployment scenarios.
Designed for durability and reliability, the D-Link DGS 1100-08PV2 operates within a wide range of environmental conditions and boasts a fanless design for silent operation, making it ideal for noise-sensitive environments. Its comprehensive suite of network management features, including VLAN support and Quality of Service (QoS), allows for efficient traffic prioritization and enhanced network security. Additionally, the inclusion of D-Link Green technology underscores a commitment to energy efficiency, automatically optimizing power usage and contributing to significant energy savings. Whether for small businesses or enterprise applications, this switch is a versatile and eco-friendly solution for modern networking needs.
  • Robust performance
    With a switching capacity of 16 Gbps and forwarding performance of 11.9 Mpps, the D-Link DGS 1100-08PV2 ensures efficient handling of network traffic, minimizing bottlenecks for smooth and reliable data transmission.
  • Enhanced connectivity
    Equipped with 8 PoE ports, this switch facilitates power and data transmission over a single cable, offering a total PoE budget of 64 W. It supports various devices such as IP cameras and VoIP phones, simplifying the network infrastructure.
  • Durable and reliable
    Designed to operate in a wide range of environmental conditions, with an operating humidity range of 0 - 90% RH and temperature tolerance from 0°C to 40°C. Its fanless design and an MTBF of 786,841 hours ensure a silent operation and less downtime.
  • Advanced network features
    Features like VLAN support, Quality of Service (QoS), and layer 2 switching capabilities enable efficient network traffic management, ensuring prioritization of critical communications and enhancing network security.
  • Eco-friendly technology
    Incorporates D-Link Green technology, optimizing energy usage and reducing power consumption. The switch automatically adjusts power usage based on the link status and cable length, contributing to energy savings.
D-Link DGS 1100-08PV2 - switch - 8 ports - smart
Switch - 8 ports - smart
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE)
Power Over Ethernet (PoE)
PoE
PoE Budget
64 W
Performance
Switching capacity: 16 Gbps , Forwarding performance: 11.9 Mpps
MAC Address Table Size
4K entries
Jumbo Frame Support
9216 bytes
Remote Management Protocol
HTTP
Flow control, Layer 2 switching, auto-negotiation, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, QoS, Cable Diagnostics Function, bandwidth control, D-Link Green Technology, fanless, 1.5MB packet buffer, WRR, loopback detection, DSCP based QoS
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
(50/60 Hz)
17.1 cm x 9.78 cm x 2.86 cm
433 g
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE
PoE Budget
64 W
Performance
4K entries
Jumbo Frame Support
9216 bytes
HTTP
Flash Memory
2 MB
8 x 1000Base-T RJ-45 PoE - 30 W
External power adapter
(50/60 Hz)
77.9 Watt
Power Consumption Stand by
2 Watt
MTBF
786,841 hours
FCC Class B certified, BSMI, cUL, CB, LVD, VCCI Class B, RoHS 10
Software Included
D-Link Network Assistant
17.1 cm
9.78 cm
2.86 cm
433 g
Limited warranty - lifetime
0 - 90% RH (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% RH (non-condensing)
Brand: D-Link
