Featuring user management interfaces, the DIS-300G is easy to manage and provides the security and controls to guard and shape your network needs.
Fanless design
With no moving parts inside to reduce downtime and maintenance call outs, the rugged housing has been optimized for the transfer of heat. -
Fast deployment
For instant installation it features a snap-to-DIN-rail clip, and also supports wall mounting. -
Withstands extreme temperatures
Operates effortlessly in industrial and harsh environments in a wide range of temperatures.
 - D-Link DIS 300G-8PSW - switch - 6 ports - Managed
 - Switch - 6 ports - Managed
- Subtype
 - Gigabit Ethernet
- Ports
 - 4 x 10/100/1000 (PoE+) + 2 x 10/100/1000 + 2 x 100/1000 SFP
- Power Over Ethernet (PoE)
 - PoE+
- PoE Budget
 - 120 W
- Capacity
 - VLANs supported: 1024 , IGMP multicast groups: up to 255 , Queues per port: 8
- MAC Address Table Size
 - 8K entries
- Jumbo Frame Support
 - 9KB
- Routing Protocol
 - IGMPv2, IGMP
- Remote Management Protocol
 - SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTPS, SSH, NTP
 - Auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, traffic shaping, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, SNTP support, STP support, RSTP support, MSTP support, DHCP snooping, QoS, DHCP server, fanless, DHCP relay, DHCP client, rugged, SPQ, DDM, AAA, IGMP querier, VLAN Double Tagging (Q-in-Q), WRR, Flooding Storm Control
 - IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.1ab (LLDP), IEEE 802.3at
- Power Redundancy
 - 7.7 cm x 15.4 cm x 12.8 cm
 - 1.308 kg
 - 5-year warranty
- Enclosure Type
 - DIN rail mountable, wall-mountable
- Subtype
 - Gigabit Ethernet
- Ports
 - PoE+
- PoE Budget
 - 120 W
- Capacity
 - 8K entries
 - 9KB
- Routing Protocol
 - IGMPv2, IGMP
- Authentication Method
 - RADIUS, TACACS+
- Status Indicators
 - Power, alarm, PoE, link/speed
 - 4 x 1000Base-T RJ-45 PoE+ , 2 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP
- Max Supported Qty
 - 2
- Power Redundancy
- MTBF
 - 25 years
 - EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, FCC Part 15, EN 61000-4-5, EN 61000-6-2, RoHS, UL 60950-1, EN 61000-6-4, WEEE, IEC 60068-2-27, IEC 60068-2-32, IEC 60068-2-6, IP30
 - 7.7 cm
 - 15.4 cm
 - 12.8 cm
 - 1.308 kg
 - Limited warranty - 5 years
 - -40 °C
 - 70 °C
 - 5 - 95%
- Min Storage Temperature
 - -40 °C
- Max Storage Temperature
 - 85 °C
- Humidity Range Storage
 - 5 - 95%
