D-Link 8 Port L2 Managed Switch 6 x 10/100/1000BaseT(X) ports (4 PoE) & 2 x 100/1000BaseSFP ports
Quicklinx: J7MCWS00 Mfr#: DIS-300G-8PSW
£900.72 ex VAT
£1,080.86 inc VAT
Featuring user management interfaces, the DIS-300G is easy to manage and provides the security and controls to guard and shape your network needs.
  • Fanless design
    With no moving parts inside to reduce downtime and maintenance call outs, the rugged housing has been optimized for the transfer of heat.
  • Fast deployment
    For instant installation it features a snap-to-DIN-rail clip, and also supports wall mounting.
  • Withstands extreme temperatures
    Operates effortlessly in industrial and harsh environments in a wide range of temperatures.
D-Link DIS 300G-8PSW - switch - 6 ports - Managed
Switch - 6 ports - Managed
Subtype
Gigabit Ethernet
Ports
4 x 10/100/1000 (PoE+) + 2 x 10/100/1000 + 2 x 100/1000 SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
120 W
VLANs supported: 1024 , IGMP multicast groups: up to 255 , Queues per port: 8
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTPS, SSH, NTP
Auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, traffic shaping, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, SNTP support, STP support, RSTP support, MSTP support, DHCP snooping, QoS, DHCP server, fanless, DHCP relay, DHCP client, rugged, SPQ, DDM, AAA, IGMP querier, VLAN Double Tagging (Q-in-Q), WRR, Flooding Storm Control
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.1ab (LLDP), IEEE 802.3at
Power Redundancy
7.7 cm x 15.4 cm x 12.8 cm
1.308 kg
5-year warranty
Enclosure Type
DIN rail mountable, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
120 W
8K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP
Authentication Method
RADIUS, TACACS+
Status Indicators
Power, alarm, PoE, link/speed
4 x 1000Base-T RJ-45 PoE+ , 2 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP
Max Supported Qty
2
Power Redundancy
MTBF
25 years
EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, FCC Part 15, EN 61000-4-5, EN 61000-6-2, RoHS, UL 60950-1, EN 61000-6-4, WEEE, IEC 60068-2-27, IEC 60068-2-32, IEC 60068-2-6, IP30
7.7 cm
15.4 cm
12.8 cm
1.308 kg
Limited warranty - 5 years
-40 °C
70 °C
5 - 95%
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Humidity Range Storage
5 - 95%
Brand: D-Link
Price Range Ex VAT: £750 - £1000
