The DGS-1100 series’ web user interface gives administrators an easy way to manage Layer 2 features, such as VLANs, Spanning Tree Protocol (STP), and link aggregation (desktop models utilize Static Trunk). With powerful security features including IGMP snooping, Static MAC, and Storm Control, these smart managed switches are a versatile solution for deployments that require easy to configure functionality without added complexities.
Simplify Network management
D-Link's free Network Assistant (DNA) utility displays all your connected devices and makes first-time configuration a breeze. The free D-View 7 Network Management System comes with a license for 25 nodes and 2 probes and full access to the management tools. -
Easy troubleshooting
The DGS-1100 Series features Loopback Detection and Cable Diagnostics to help network administrators find and solve network problems quickly and easily. Loopback Detection detects loops created by a specific port and automatically shuts down the affected port. The Cable Diagnostics feature is designed for network administrators to quickly examine the quality of the copper cables, recognize the cable type, and detect cable errors. -
Green technology
D-Link Green technology enables the DGS-1100 Smart Managed Switches to save power without sacrificing performance. The desktop models in the series utilize a fanless design, for silent and energy-efficient operation. All models are also IEEE 802.3az-compliant and feature Link Status detection.
 - D-Link DGS 1100-08V2 - switch - 8 ports - smart
 - Switch - 8 ports - smart
- Subtype
 - Gigabit Ethernet
- Ports
 - 8 x 10/100/1000
- Performance
 - Switching capacity: 16 Gbps , Forwarding performance: 11.9 Mpps
- Capacity
 - VLAN groups: 128 , VLAN IDs: 4094 , IGMP groups: 128
- MAC Address Table Size
 - 4K entries
- Routing Protocol
 - IGMPv2, IGMP, IGMPv3
- Remote Management Protocol
 - SNMP 2, ICMP
 - Flow control, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, STP support, RSTP support, QoS, Cable Diagnostics Function, bandwidth control, fanless, LLDP support, Port Security, DHCP client, tagged VLAN, DSCP support, 1.5MB packet buffer, IGMP querier, Voice VLAN, VLAN management, VLAN group, EEE, WRR, HOL Blocking Prevention, loopback detection, port-based VLAN, port-based QoS, Unknown Storm Control, DNA support, Asymmetric VLAN
 - IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1ab (LLDP), IEEE 802.3az
- Power
 - AC 100/240 V (50/60 Hz)
 - 14.5 cm x 8.2 cm x 2.8 cm
 - 340 g
- Enclosure Type
 - Desktop
- Subtype
 - Gigabit Ethernet
- Ports
 - 8 x 10/100/1000
- Performance
- Capacity
 - 4K entries
- Routing Protocol
 - SNMP 2, ICMP
- Encryption Algorithm
 - SSL
- Flash Memory
 - 2 MB
- Status Indicators
 - Power, status, link/activity/speed
 - 8 x 1000Base-T RJ-45
- Power Device
 - External power adapter
- Voltage Required
- Power Consumption Stand by
 - 1.93 Watt
- MTBF
 - 1,456,992 hours
 - FCC Class A certified, C-Tick, BSMI, cUL, CB, CCC, RoHS, LVD, VCCI Class A
- Software Included
 - D-Link Network Assistant
 - 14.5 cm
 - 8.2 cm
 - 2.8 cm
 - 340 g
 - 0 °C
 - 40 °C
 - 0 - 90% (non-condensing)
- Min Storage Temperature
 - -40 °C
- Max Storage Temperature
 - 70 °C
- Humidity Range Storage
 - 0 - 95% (non-condensing)
