D-Link 8-Port Gigabit Ethernet Metal Housing Unmanaged Switch
Quicklinx: J7LKWS00 Mfr#: DGS-108GL/B
Hurry, only 1 left in stock!
£19.14 ex VAT
£22.96 inc VAT
The DGS-108GL boasts peak value for home offices or SMBs in enabling easy and rapid network expansions, upgrading connections with a hassle-free plug and play switch solution.
  • Slim dimensions, hefty performance
    The DGS-108GL 8 Port Gigabit Unmanaged Desktop Switch is ideal for home offices or small to medium-sized businesses (SMB) to add a quick and easy Gigabit upgrade to the network. The DGS-108GL packs full functionality and Gigabit performance into a slim yet sturdy metal design.
  • Better for your budget, better for the planet
    The eco-friendly DGS-108GL is compliant with Energy-Efficient Ethernet (IEEE 802.3az) standards to save energy and reduce heat emissions without sacrificing performance and functionality. When low-traffic or idle interface ports are detected, the DGS-108GL automatically transitions them into a low-power state, substantially reducing overall device power consumption.
  • Ready to serve for years to come
    The DGS-108GL features a fanless design for silent operation, reduced energy consumption, and enhanced reliability by eliminating a common point of failure for an extended product life.
  • Setup that doesn't dent your productivity
    Expanding your network shouldn't take a whole morning of navigating complex setup software. Simply place the DGS-108GL on a desktop or conveniently wall mount, connect it to your network via Ethernet cables and you're set.
D-Link DGS 108GL - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Switching capacity: 16 Gbps , Packet filter/forwarding rate (10 Mbps): 14880 pps , Packet filter/forwarding rate (100 Mbps): 148800 pps , Packet filter/forwarding rate (1000 Mbps):: 1488000 pps , Forwarding rate: 11.9 Mpps
Queues: 8
MAC Address Table Size
4K entries
Jumbo Frame Support
9216 bytes
Flow control, auto-uplink (auto MDI/MDI-X), store and forward, QoS, D-Link Green Technology, fanless, metal housing, VoIP support, NAS support, SOHO, EEE
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
14 cm x 6.7 cm x 2.6 cm
240 g
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Queues: 8
4K entries
Jumbo Frame Support
9216 bytes
Status Indicators
Power, link/activity
8 x 1000Base-T RJ-45
External power adapter
Power Provided
DC 5 V - 1 A
Power Consumption Stand by
0.93 Watt
MTBF
1,402,428 hours
Plug and Play, FCC, RoHS
14 cm
6.7 cm
2.6 cm
240 g
Limited warranty - lifetime
10 - 90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% (non-condensing)
Brand: D-Link
