D-Link 8-Port Fast Ethernet PoE Unmanaged Desktop Switch
Quicklinx: 9H7KWS00 Mfr#: DES-1008PA
Type: Fast Ethernet
Ports: 8
Data Transfer Rate: 100Mbps
Managed: No
POE: PoE
Hurry, only 1 left in stock!
£48.16 ex VAT
£57.79 inc VAT
The D-Link DES-1008PA 8-Port Fast Ethernet PoE Desktop Switch enables both home and office users to easily connect and supply power to Power over Ethernet (PoE) devices such as wireless Access Points (APs), IP cameras, and IP phones while adding more Ethernet devices like computers, printers, and Network Attached Storage (NAS) onto a network. Built with home and small business users in mind, this compact PoE switch operates silently, making it ideal for use in virtually any room or office.
  • Efficient connectivity
    The D-Link DES 1008PA switch offers efficient connectivity with its 8 Fast Ethernet ports, enabling high-speed network connections for multiple devices.
  • Enhanced power management
    With Power Over Ethernet (PoE) support on 4 ports, this switch facilitates power and data transmission over a single cable, simplifying installations and reducing cable clutter.
  • Reliable performance
    Designed to support a MAC Address Table Size of 1K entries and featuring auto-negotiation and store and forward capabilities, the D-Link DES 1008PA ensures reliable, efficient network performance.
  • Broad compatibility
    This switch is compatible with PC systems, making it a versatile addition to any home or office network setup.
  • Durable and compliant
    The D-Link DES 1008PA adheres to multiple IEEE standards and is FCC Class B certified, ensuring a durable, compliant solution for your networking needs.
D-Link DES 1008PA - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Fast Ethernet
Ports
4 x 10/100 (PoE) + 4 x 10/100
PoE
1K entries
Auto-sensing per device, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3, IEEE 802.3u, IEEE 802.3af, IEEE 802.3x
17 cm x 9.9 cm x 2.8 cm
454 g
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
PoE
1K entries
Status Indicators
Port status, power, link OK, 100M device connected, link/activity
4 x 100Base-TX RJ-45 PoE , 4 x 100Base-TX RJ-45
External power adapter
17 cm
9.9 cm
2.8 cm
454 g
5 - 90%
9H7K C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.80
Type: Fast Ethernet
Ports: 8
Managed: No
POE: PoE
Brand: D-Link
