The D-Link DES-1008PA 8-Port Fast Ethernet PoE Desktop Switch enables both home and office users to easily connect and supply power to Power over Ethernet (PoE) devices such as wireless Access Points (APs), IP cameras, and IP phones while adding more Ethernet devices like computers, printers, and Network Attached Storage (NAS) onto a network. Built with home and small business users in mind, this compact PoE switch operates silently, making it ideal for use in virtually any room or office.
Efficient connectivity
The D-Link DES 1008PA switch offers efficient connectivity with its 8 Fast Ethernet ports, enabling high-speed network connections for multiple devices. -
Enhanced power management
With Power Over Ethernet (PoE) support on 4 ports, this switch facilitates power and data transmission over a single cable, simplifying installations and reducing cable clutter. -
Reliable performance
Designed to support a MAC Address Table Size of 1K entries and featuring auto-negotiation and store and forward capabilities, the D-Link DES 1008PA ensures reliable, efficient network performance. -
Broad compatibility
This switch is compatible with PC systems, making it a versatile addition to any home or office network setup. -
Durable and compliant
The D-Link DES 1008PA adheres to multiple IEEE standards and is FCC Class B certified, ensuring a durable, compliant solution for your networking needs.
- D-Link DES 1008PA - switch - 8 ports - unmanaged
- Switch - 8 ports - unmanaged
- Subtype
- Fast Ethernet
- Ports
- 4 x 10/100 (PoE) + 4 x 10/100
- Power Over Ethernet (PoE)
- PoE
- MAC Address Table Size
- 1K entries
- Auto-sensing per device, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
- IEEE 802.3, IEEE 802.3u, IEEE 802.3af, IEEE 802.3x
- 17 cm x 9.9 cm x 2.8 cm
- 454 g
- Enclosure Type
- Desktop
- Subtype
- Fast Ethernet
- Ports
- PoE
- 1K entries
- Status Indicators
- Port status, power, link OK, 100M device connected, link/activity
- 4 x 100Base-TX RJ-45 PoE , 4 x 100Base-TX RJ-45
- Power Device
- External power adapter
- FCC Class B certified
- 17 cm
- 9.9 cm
- 2.8 cm
- 454 g
- 0 °C
- 40 °C
- 5 - 90%
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £13.93 |
