The DES-1008D 8-Port Fast Ethernet Unmanaged Desktop Switch is an 8-port 10/100 Mbps Fast Ethernet switch that allows you to quickly set up a wired network. Connect the DES-1008D to multiple computers together to share files and folders, or connect it to a router to share an Internet connection.
- D-Link DES 1008D - switch - 8 ports - unmanaged
- Switch - 8 ports - unmanaged
- Subtype
- Fast Ethernet
- Ports
- 8 x 10/100
- MAC Address Table Size
- 8K entries
- Flow control, auto-sensing per device, auto-negotiation, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x
- Power
- AC 100/240 V
- 19.2 cm x 11.8 cm x 3.2 cm
- 301 g
- Enclosure Type
- Desktop
- Subtype
- Fast Ethernet
- Ports
- 8 x 10/100
- 8K entries
- RAM
- 256 KB
- Status Indicators
- Collision status, port transmission speed, port duplex mode, power, link/activity
- 8 x 100Base-TX RJ-45
- Power Device
- External power adapter
- Voltage Required
- AC 100/240 V
- 2 Watt
- FCC Class B certified, VCCI Class A ITE
- 19.2 cm
- 11.8 cm
- 3.2 cm
- 301 g
- 0 °C
- 50 °C
- 10 - 90%
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £13.89 |
