The DMS-107 is a multi-Gigabit Ethernet Plug-and-Play switch that provides ultrafast connectivity to your network core or network-attached storage (NAS) device. You can easily connect multiple computers within minutes, and start sharing an Internet connection, files, music, and video across your small office or home network.
Ready for Wi-Fi 6
It comes with multi-Gigabit ports for maximum throughput and performance - ideal for enjoying unrestricted Wi-Fi 6 devices, high-end gaming computers and workstations. The multi-Gigabit ports eliminate potential bottlenecks with Wi-Fi 6 access points, allowing your network to take full advantage of the efficiency and speeds provided by Wi-Fi 6. -
Effortless traffic optimization
With 2.5 Gigabit transfer speeds on uplink ports, you can rapidly transfer files between connected servers and network-attached storage (NAS) to computers. The switch's 802.1p Quality of Service (QoS) functionality on Gigabit ports automatically organizes and prioritizes time-sensitive and critical data for efficient delivery, allowing for buffer-free video streaming as well as smooth video and voice calls. -
Plug-and-Play convenience
The DMS-107 is a Plug-and-Play device that requires no advanced technical configuration. Plug-and-Play makes it easy to instantly create a network connected to the Internet. -
Designed for life, built to last
The DMS-107 features a fanless design for silent operation, reduced energy consumption, and increased reliability by eliminating a common point of failure. Its sturdy compact metal housing ensures the product can withstand wider operating temperatures by helping to dissipate heat and reduce stress on internal components. -
Energy-saving
The compact, metal housing and fanless design mean the switch can be placed virtually anywhere and operate silently. The DMS-107 is designed with energy efficiency in mind. The switch automatically reduces power to ports that are inactive or not connected, and supports the IEEE 802.3az Energy-Efficient Ethernet standard.
- D-Link DMS 107 - switch - 7 ports - unmanaged
- Switch - 7 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000 + 2 x 2.5GBase-T
- Performance
- Switching capacity: 20 Gbps , Packet forwarding rate: 14.88 Mpps
- Capacity
- Packet buffer size: 2 MB
- MAC Address Table Size
- 2K entries
- Jumbo Frame Support
- 9216 bytes
- Flow control, auto-uplink (auto MDI/MDI-X), store and forward, Link Fault Detection, Quality of Service (QoS), D-Link Green Technology, fanless, metal housing, Energy-Efficient Ethernet (EEE), auto firmware update
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az, IEEE 802.3bz
- 14.5 cm x 8.2 cm x 2.8 cm
- 295.2 g
- Localisation
- United Kingdom
- 2-year warranty
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- Capacity
- 2K entries
- 9216 bytes
- Status Indicators
- Power, link/activity
- 5 x 10/100/1000 Base-T RJ-45 , 2 x 10/100/1000/2.5G RJ-45
- Power Device
- External power adapter
- Power Provided
- DC 12 V - 0.5 A
- MTBF
- 944,277.78 hours
- Plug and Play, FCC Class B certified, IC Class B, BSMI, RoHS, BSMI Class B, LVD, VCCI Class B, RCM Class B
- Localisation
- United Kingdom
- 14.5 cm
- 8.2 cm
- 2.8 cm
- 295.2 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 90% RH
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 95% RH
