D-Link 7-Port Multi-Gigabit Unmanaged Switch
Quicklinx: J7LNWS00 Mfr#: DMS-107/B
18 In Stock
£43.51 ex VAT
£52.21 inc VAT
The DMS-107 is a multi-Gigabit Ethernet Plug-and-Play switch that provides ultrafast connectivity to your network core or network-attached storage (NAS) device. You can easily connect multiple computers within minutes, and start sharing an Internet connection, files, music, and video across your small office or home network.
  • Ready for Wi-Fi 6
    It comes with multi-Gigabit ports for maximum throughput and performance - ideal for enjoying unrestricted Wi-Fi 6 devices, high-end gaming computers and workstations. The multi-Gigabit ports eliminate potential bottlenecks with Wi-Fi 6 access points, allowing your network to take full advantage of the efficiency and speeds provided by Wi-Fi 6.
  • Effortless traffic optimization
    With 2.5 Gigabit transfer speeds on uplink ports, you can rapidly transfer files between connected servers and network-attached storage (NAS) to computers. The switch's 802.1p Quality of Service (QoS) functionality on Gigabit ports automatically organizes and prioritizes time-sensitive and critical data for efficient delivery, allowing for buffer-free video streaming as well as smooth video and voice calls.
  • Plug-and-Play convenience
    The DMS-107 is a Plug-and-Play device that requires no advanced technical configuration. Plug-and-Play makes it easy to instantly create a network connected to the Internet.
  • Designed for life, built to last
    The DMS-107 features a fanless design for silent operation, reduced energy consumption, and increased reliability by eliminating a common point of failure. Its sturdy compact metal housing ensures the product can withstand wider operating temperatures by helping to dissipate heat and reduce stress on internal components.
  • Energy-saving
    The compact, metal housing and fanless design mean the switch can be placed virtually anywhere and operate silently. The DMS-107 is designed with energy efficiency in mind. The switch automatically reduces power to ports that are inactive or not connected, and supports the IEEE 802.3az Energy-Efficient Ethernet standard.
D-Link DMS 107 - switch - 7 ports - unmanaged
Switch - 7 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000 + 2 x 2.5GBase-T
Performance
Switching capacity: 20 Gbps , Packet forwarding rate: 14.88 Mpps
Packet buffer size: 2 MB
MAC Address Table Size
2K entries
Jumbo Frame Support
9216 bytes
Flow control, auto-uplink (auto MDI/MDI-X), store and forward, Link Fault Detection, Quality of Service (QoS), D-Link Green Technology, fanless, metal housing, Energy-Efficient Ethernet (EEE), auto firmware update
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az, IEEE 802.3bz
14.5 cm x 8.2 cm x 2.8 cm
295.2 g
United Kingdom
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
Performance
2K entries
Jumbo Frame Support
9216 bytes
Status Indicators
Power, link/activity
5 x 10/100/1000 Base-T RJ-45 , 2 x 10/100/1000/2.5G RJ-45
External power adapter
Power Provided
DC 12 V - 0.5 A
MTBF
944,277.78 hours
Plug and Play, FCC Class B certified, IC Class B, BSMI, RoHS, BSMI Class B, LVD, VCCI Class B, RCM Class B
United Kingdom
14.5 cm
8.2 cm
2.8 cm
295.2 g
10 - 90% RH
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% RH
Brand: D-Link
