D-Link 60W Ultra slim design with 52.5mm (3SU) width Power Supply
Quicklinx: J7MQWS00 Mfr#: DIS-H60-24
£36.90 ex VAT
£44.28 inc VAT
The D-Link power supply is engineered to meet the rigorous demands of network hardware environments. With a high efficiency rate of 90%, it not only delivers reliable power but also operates with minimal energy waste, making it an environmentally friendly choice. Its robust design ensures it can function in a wide range of temperatures, from the cold extremes of -30°C to the heat of 70°C, without compromising performance. Safety is paramount, and this power supply comes equipped with overload, overvoltage, and short-circuit protection, ensuring your network hardware is safeguarded against potential damage. With an impressive MTBF of 927,600 hours, it promises reliability. Its compatibility with a broad input voltage range and DIN rail mountable form factor makes it a versatile and easy-to-install solution for any network infrastructure.
  • Robust performance
    Designed to operate in a wide range of environmental conditions, this power supply maintains its functionality in temperatures from -30°C to 70°C, ensuring reliable performance in extreme conditions.
  • High efficiency
    With an efficiency rate of 90%, this power supply ensures optimal performance while minimizing energy consumption, making it an eco-friendly choice for powering network hardware.
  • Enhanced safety features
    Equipped with overload, overvoltage, and short-circuit protection, this power supply ensures safe and uninterrupted operation, protecting both the device and the network infrastructure it supports.
D-Link - power supply - 60 Watt
Power supply - DIN rail mountable
Output Voltage
DC 24 V
Power Capacity
60 Watt
5.25 cm x 5.45 cm x 9 cm
3-year warranty
Input Voltage Range
AC 85 - 264 / 277 V
Frequency Required
47 - 63 Hz
Output Voltage
DC 24 V
Max Electric Current
2.5 A
Power Capacity
60 Watt
Efficiency
90%
MTBF
927,600 hours
Over voltage protection, overload protection, short-circuit protection
UL 60950-1, IEC 60950-1, UL 508, EN61000-3-2, EN 61558-2-16
Limited warranty - 3 years
-30 °C
70 °C
20 - 90% (non-condensing)
5.25 cm
5.45 cm
9 cm
Brand: D-Link
