D-Link 6-port Multi-Gigabit Unmanaged Switch
Quicklinx: J7LLWS00 Mfr#: DMS-106XT
22 In Stock
£160.81 ex VAT
£192.97 inc VAT
The D-Link DMS 106XT switch is engineered to meet the demands of modern networks, offering robust performance, versatile connectivity, and advanced networking features. With a switching capacity of 35 Gbps and a packet filter/forwarding rate of 1,488,000 packets per second, it ensures efficient data flow and high-speed connectivity for all connected devices. The switch is equipped with five 100/1000/2.5G ports and one 10Gbit LAN port, providing flexible connection options for a wide range of devices. Its fanless design not only reduces operational costs but also minimizes noise, making it ideal for quiet office environments. Additionally, the DMS 106XT supports Quality of Service (QoS) for traffic prioritization, Turbo Mode for enhanced performance, and auto-uplink (auto MDI/MDI-X) for easy network integration. Designed to operate in a wide range of environmental conditions and boasting an MTBF of 489,941 hours, the D-Link DMS 106XT is a reliable and durable choice for any network.
  • Ultra-fast 10-Gigabit connection for home or office applications
    A 10-Gigabit port for high-bandwidth network uplink or access to a Network Attached Storage (NAS), perfect for the multimedia design workplace.
  • 2.5-Gigabit ports ready for Wi-Fi 6 connectivity
    With five 2.5-Gigabit ports to connect all your high-speed devices, such as Wi-Fi 6 routers and access points, the DMS-106XT delivers unrestricted multi-Gigabit network access for your home or small business.
  • Designed for advanced home or small office networks
    Fast enough to handle your large multimedia file transfers to and from the storage server with the 10-Gigabit port, and versatile enough to keep your Wi-Fi 6 router and AP communications unrestricted with 5 multi-Gigabit (2.5 Gbps) ports. When play time begins, simply flick the Turbo Mode switch for uninterrupted movie streams and lag-free online gaming. The sleek aluminum alloy design and multi-colored LED light bar make the DMS-106XT a great addition to any modern home or workplace.
D-Link DMS 106XT - switch - 6 ports - smart
Switch - 6 ports - smart
Subtype
2.5 Gigabit Ethernet
Ports
5 x 100/1000/2.5G + 1 x 100/1000/2.5G/5G/10G (uplink)
Performance
Switching capacity: 35 Gbps , Packet filter/forwarding rate: 1488000 packets per second
MAC Address Table Size
4K entries
Flow control, auto-uplink (auto MDI/MDI-X), store and forward, Turbo Mode, QoS, fanless, rugged, EEE, 4K HD video streaming, MDI, MDI-X
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3an, IEEE 802.3az, IEEE 802.3bz
AC 100-240 V
16.3 cm x 21.7 cm x 3.3 cm
680 g
Matte grey
Enclosure Type
Desktop
Subtype
Ports
Performance
4K entries
Status Indicators
Power, link/activity
5 x 100/1000/2.5G RJ-45 , 1 x 10Gbit LAN RJ-45 uplink
External power adapter
Installed Qty
1
AC 100-240 V
Matte grey
MTBF
489,941 hours
Plug and Play, VCCI, BSMI, FCC, RoHS, RCM
16.3 cm
21.7 cm
3.3 cm
680 g
10 - 95% RH
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% RH
Brand: D-Link
