The DNR-2060-08P JustConnect Network Video Recorder is a comprehensive standalone network video display, storage, and management solution providing reliable high quality monitoring for IP-based security systems. The DNR-2060-08P enables simultaneous recording and remote access to recorded videos as well as live view.
Maximizing the potential
The latest multi-megapixel resolution cameras demand a network recording solutions. The DNR-2060-08P exceeds these demands and adds reliability, scalability, flexibility, ease of use and competitive pricing. -
The DNR-2060-08P has eight built-in 802.3at compliant PoE+ ports that simplifi es camera installation by providing both power and network connectivity through a simple cable. Not only does this save overall installation cost by eliminating the need to install separate electrical wiring and power outlet, PoE+ allows you to power even the most demanding cameras.
- D-Link DNR-2060-08P JustConnect Multifunctional Network Video Recorder - standalone DVR - 8 channels
- Standalone DVR - 8 channels - networked
- Frame Rate
- 240 fps (NTSC), 200 fps (PAL) (record) / 60 fps (NTSC), 50 fps (PAL), 100 fps (PAL), 120 fps (NTSC), 200 fps (PAL), 240 fps (NTSC) (playback)
- Compression Format
- MJPEG, H.264
- TV System
- NTSC/PAL
- Image Resolution
- 1280x720, 1920x1080, 1024x768, 1280x1024
- Hard Drive(s) Supported
- Quantity: 6 - total capacity: 18 TB
- 44.04 cm x 45.09 cm x 9.04 cm
- 9.02 kg
- Standalone DVR
- Video Channels
- 8
- TV System
- NTSC/PAL
- Image Resolution
- MJPEG, H.264
- Package Content
- DVR
- C-Tick, FCC
Security DVR
- Frame Rate (Playback)
- 60 fps (NTSC), 50 fps (PAL), 100 fps (PAL), 120 fps (NTSC), 200 fps (PAL), 240 fps (NTSC)
- Frame Rate (Record)
- Networked
- Motion detection
Hard Drive
- Quantity Supported
- 6
- Interface
- Serial ATA
- Supported Max Total Capacity
- 18 TB
- Network Interfaces
- Ethernet 10Base-T/100Base-TX/1000Base-T
- Supported Protocols
- DHCP, DNS, HTTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, IPv4, PPPoE
- PoE+
- Alarm Ports
- Alarm output x 1
- Network Port
- 10/100Base-T x 8 / 1000Base-T x1
- Other Ports
- USB 2.0 x 3, eSATA x 1, VGA x 1
- 44.04 cm
- 45.09 cm
- 9.04 cm
- 9.02 kg
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
